| | | PIN TO PIN |
制程 | 22nm | 28nm | 14nm | 14nm |
封装 | FCCSP565L 15.5mm*14.4mm*0.9mm 0.65mm&0.4mm pitch | TFBGA418L 14mm*14mm*1.2mm 0.65mm pitch | 0.65mm pitch | FCCSP409 14mm*14mm*0.9mm 0.65mm pitch |
| 64bit Quad-Core A55, up to 1.8GHz | 64-bit Quad-Core A35, up to 1.5GHz | Quad-Core Cortex-A7 up to 1.5GHz | Dual-Core Cortex-A7 up to 1.5GHz |
| Mali-G52-2EE 800MHz | Mali-G31MP2 520MHz | N/A | N/A |
| N/A | N/A | N/A | N/A |
CPU RAM | one Channel DDR controller up to 8G Byte, DDR3/3L-800Mbps, LPDDR4-1056Mbps LPDDR4X-1056Mbps | one channel DDR controller up to 4G Byte, DDR3/3L-1600Mbps, LPDDR3-1600Mbps, LPDDR2-1066Mbps, DDR4-1600Mbps | one channel DDR controller up to 4G Byte, DDR4-?Mbps, DDR3/3L-1066Mbps, LPDDR3-1066Mbps, LPDDR4-1066Mbps | one channel DDR controller up to 4G Byte, DDR4-?Mbps, DDR3/3L-1066Mbps, LPDDR3-1066Mbps, LPDDR4-1066Mbps |
NPU | Up to 0.8TOPS | N/A | Up to 2.0TOPS | Up to 1.2TOPS |
NPU RAM | N/A | N/A | N/A | N/A |
| HS200 mode | NAND, Compatible with eMMC SPECification 4.41, 4.51, 5.0 and 5.1 | NAND, Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | NAND, Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 |
| 4K@60fps H.264&H.265&VP9 profile0/2 video decode,1080P multi video decode | H.264/H.265 1080p@60fps video decode | 4K@30fps H.264/H.265 | 5M H.264/H.265 |
Video Encode | 1080p@100fps video encoding for H.264 and H.265 | 1080p@30fps video encoding for H.264 | 4K@30fps + 1080p@30fps | 5M@30fps + 720p@30fps |
Codec | N/A | N/A | N/A | N/A |
| | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc |
| SDIO3.0 | SDIO3.0 | SDIO3.0 | SDIO3.0 |
SD/MMC Interface | SD3.0/MMC4.51 | SD3.0/MMC4.51 | SD3.0/MMC4.51 | SD3.0/MMC4.51 |
| N/A | YES | N/A | N/A |
PCIe | PCIe2.1, Compatible with PCI Express Base Specification Revision 3.0 | N/A | N/A | N/A |
| Up to 6.0Gbps,SATA3.0 x 2 Compatible with Serial ATA3.3 and AHCI Revision 1.3.1 | N/A | N/A | N/A |
| | up to 1920*1080,MIPI,RGB,1 Channel LVDS, | up to 1920*1080,MIPI,RGB | up to 1920*1080,MIPI,RGB |
| HDMI2.0 | N/A | N/A | N/A |
CVBS OUT/IN | N/A | N/A | N/A | N/A |
| one 8M@30fps ISP,可分时复用满足双摄; MIPI-CSI 4lane,可拆分成2x2lane两组独立使用; and DVP interface | one 8M ISP, MIPI-CSI and DVP interface | one 14M ISP, 2 MIPI-CSI/LVDS/SubLVDS and DVP interface | one 5M ISP, 2 MIPI-CSI/LVDS/SubLVDS and DVP interface |
TYPE C Interface | N/A | N/A | N/A | N/A |
USB3.0 | Up to 5Gbps, USB HOST3.0 x 1 | N/A | N/A | N/A |
USB2.0 | USB Host2.0 x 3 | USB OTG2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 1 |
MAC | 10/100/1000M Ethernet Controller | N/A | 10/100/1000M Ethernet Controller | 10/100/1000M Ethernet Controller |
PHY | N/A | N/A | N/A | N/A |
| 8 CH I2S x 2 and 2 CH I2S x 2 | 8 CH I2S x 1 and 2 CH I2S x 2 | 8 CH I2S x 1 and 2 CH I2S x 2 | 8 CH I2S x 1 and 2 CH I2S x 2 |
PDM/TDM Interface | 8 CH PDM x 1 and 8 CH TDM x 1 | 8 CH PDM x 1 and 8 CH TDM x 1 | 8 CH PDM x 1 8 CH TDM x 1 | 8 CH PDM x 1 8 CH TDM x 1 |
SPDIF | YES | N/A | N/A | N/A |
SPI | SPI x 4 | SPI x 2 | SPI x 2 | SPI x 2 |
| UART x 10 | UART x 4 | UART x 6 | UART x 6 |
| I2C x 6 | I2C x 3 | I2C x 6 | I2C x 6 |
| PWM x 16 | PWM x 2 | PWM x 12 | PWM x 12 |
双屏异显 | N/A | N/A | N/A | N/A |
工作温度 | 0℃~80℃ | 0℃~80℃ | RK1126 :0℃~80℃ RK1126K:-40℃~85℃ | 0℃~80℃ |
| | RK809-1 RK817-1 | RK809-2 | RK809-2 |
