| | | | RK812 | | | |
封装 | QFN68 7mm*7mm*0.8mm 0.35mm pitch | QFN68 7mm*7mm*0.8mm 0.35mm pitch | QFN40
5mm*5mm*0.8mm 0.4mm pitch | QFN36
4mm*4mm*0.6mm 0.35mm pitch | QFN68 7mm*7mm*0.8mm 0.35mm pitch | QFN68 7mm*7mm*0.8mm 0.35mm pitch | QFN32
4mm*4mm*0.8mm 0.4mm pitch |
USB or Dc Input | USB Input 3.8V ~ 5.5V | USB Input 3.8V ~ 5.5V | USB Input 3.8V ~ 5.5V | USB Input 3.8V ~ 5.5V | DC Input 2.7V ~ 5.5V | DC Input 2.7V ~ 5.5V | DC Input 2.7V ~ 5.5V |
BAT Input | 2.7V ~ 4.5V | 2.7V ~ 5.5V | 2.7V ~ 4.5V | 2.7V ~ 5.5V | N/A | N/A | N/A |
| Up to 4.35V | Up to 4.45V | Up to 4.35V | Line mode charger Up to 4.45V | N/A | N/A | N/A |
BUCK1 | 2.7V ~ 5.5V input 0.7125V ~ 1.5V output 4A max output | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 2.5A max output | 2.7V ~ 5.5V input 0.7125V ~ 2.3V output 2A max output | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 1.5A max output | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 2.5A max output | 2.7V ~ 5.5V input 0.7125V ~ 1.5V output 5A max output | 2.7V ~ 5.5V input 0.7125V ~ 2.3V output 2.5A max output |
BUCK2 | 2.7V ~ 5.5V input 0.7125V ~ 1.5V output 4A max output | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 2.5A max output | 2.7V ~ 5.5V input 0.7125V ~ 2.3V output 2A max output | N/A | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 2.5A max output | 2.7V ~ 5.5V input 0.7125V ~ 1.5V output 5A max output | 2.7V ~ 5.5V input 0.7125V ~ 2.3V output 2.5A max output |
BUCK3 | 2.7V ~ 5.5V input 2.5A max output Feedback Voltage 1V | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 1.5A max output Feedback Voltage 0.8V | 2.7V ~ 5.5V input 1A max output Feedback Voltage 0.8V | N/A | 2.7V ~ 5.5V input 0.5V ~ 2.4V output 1.5A max output Feedback Voltage 0.8V | 2.7V ~ 5.5V input 3A max output Feedback Voltage 1V | 2.7V ~ 5.5V input 1.5A max output Feedback Voltage 0.8V |
BUCK4 | 2.7V ~ 5.5V input 1.8V ~ 3.6V output 2.5A max output | 2.7V ~ 5.5V input 0.5V ~ 3.4V output 1.5A max output | 2.7V ~ 5.5V input 0.8V ~ 3.5V output 1A max output | N/A | 2.7V ~ 5.5V input 0.5V ~ 3.4V output 1.5A max output | 2.7V ~ 5.5V input 1.8V ~ 3.3V output 2.5A max output | 2.7V ~ 5.5V input 0.8V ~ 3.5V output 1.5A max output |
BUCK5 | N/A | N/A | N/A | N/A | 2.7V ~ 5.5V input 1.5V ~ 3.6V output 2.5A max output | N/A | N/A |
| 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output | 2.7V ~ 5.5V input 0.6V ~ 3.4V output 600mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | 2V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output |
LDO2 | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output | 1.8V ~ 5.5V input 0.6V ~ 2.0V output 400mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | 2V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output |
LDO3 | 2.7V ~ 5.5V input 0.8V ~ 2.5V output 100mA max output | high PSRR 2V ~ 5.5V input 0.6V ~ 3.4V output 100mA max output | Low noise high PSRR 2.7V ~ 5.5V input 0.8V ~ 3.4V output 100mA max output | N/A | high PSRR 2V ~ 5.5V input 0.6V ~ 3.4V output 100mA max output | Low noise high PSRR 2.7V ~ 5.5V input 0.8V ~ 2.5V output 100mA max output | Low noise high PSRR 2V ~ 5.5V input 0.8V ~ 3.4V output 100mA max output |
LDO4 | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 100mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 150mA max output | N/A |
LDO5 | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 300mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output | 2V ~ 5.5V input 1.8V ~ 3.4V output 100mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 300mA max output | N/A |
LDO6 | 2.7V ~ 5.5V input 0.8V ~ 2.5V output 150mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 3.4V output 300mA max output | N/A | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 2.5V output 150mA max output | N/A |
LDO7 | 2.7V ~ 5.5V input 0.8V ~ 2.5V output 300mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | N/A | N/A | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 0.8V ~ 2.5V output 300mA max output | N/A |
LDO8 | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 400mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | N/A | N/A | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 300mA max output | N/A |
LDO9 | 2.7V ~ 5.5V input 1.8V ~ 3.4V output 300mA max output | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | N/A | N/A | 2V ~ 5.5V input 0.6V ~ 3.4V output 400mA max output | N/A | N/A |
Switch1 | 2.7V ~ 5.5V input | N/A | N/A | N/A | 2.7V ~ 5V input | 2.7V ~ 5V input | N/A |
Switch2 | N/A | N/A | N/A | N/A | 2.7V ~ 5V input | 2.7V ~ 5V input | N/A |
| 80mA output | N/A | N/A | N/A | N/A | N/A | N/A |
| 800mA output | 1A/1.5A/1.8A/2.1A output | 850mA output | N/A | N/A | N/A | N/A |
Codec | N/A | YES | N/A | YES | YES | N/A | N/A |
Part Number | RK818-1 RK818-2 RK818-3 | RK817-1 | RK816B-1 RK816B-2 RK816B-3 | RK812-1 | RK809-1 RK809-2 RK809-3 | RK808-B RK808-C RK808-D | RK805-1 RK805-2 RK805-3 |
工作温度 | -40℃~125℃ | -40℃~125℃ | -40℃~125℃ | -40℃~125℃ | -40℃~125℃ | -40℃~125℃ | -40℃~125℃ |
搭配的AP | RK818-2:Sofia 3GR RK818-3:RK3399 | |
| | RK809-1:PX30 | RK808-B:RK3288&RK3368 RK808-C:RK3288 Chrome Book RK808-D:RK3399 | RK805-2:RV1108 |
