RK628D是一款高集成度接口
芯片,可支持HDMI/并口RGB/BT.1120作为输入,双MIPI/双LVDS/GVI(通用视频接口)/并口RGB/BT.1120作为输出,内置特色缩放器。 关键应用场景是为
RK3288/RK3399等原始应用处理器扩展显示输出端口,或提供HDMI接口。
绝对最大额定值
Parameters | Related Power Group | Max | Unit |
DC supply voltage for internal digital logic@l.lv | DVDD_1,DVDD_2 | 1.3 | V |
DC supply voltage for digital GPI0@1.8V mode | VCCIO2_1,VCCIO2_2 | 2.3 | V |
DC supply voltage for digital GPIO@3.3V mode | VCCIO1,VCCIO2_1,VCCIO2_2 | 3.8 | V |
DC supply voltage for HDMI RX | HDMIRX_AVDD_3V3 | 3.8 | V |
HDMIRX_DVDD_1V1 | 1.3 |
DC supply voltage for GVI/LVDS/MIPI TX | GVI/LVDS/MIPI_PLL_AVDD_3V3 GVI/LVDS/MIPI_AVDD_3V3 | 3.8 | V |
GVI/LVDS/MIPI_AVDD_1V1 | 1.3 |
DC supply voltage for HDMI TX | HDMITX_DVDD_1V1 | 1.3 | V |
HDMITX_AVDD_3V3 | 3.8 |
DC supply voltage for PLL | PLL_AVDD_1V1 | 1.3 | V |
PLL_AVDD_3V3 | 3.8 |
DC supply voltage for EFUSE | EFUSE_VDD_2V5 | 2.75 | V |
Storage Temperature | Tstg | 125 | °C |
Max Conjunction Temperature | Tj | 125 | °C |
RK628D直流特性
Parameters | Symbol | Min | Typ | Max | Units |
Digital GPIO @3.3V for GPIO0/1/2/3 | Input Low Voltage | Vil | -0.3 | NA | 0.8 | V |
Input High Voltage | Vih | 2.0 | NA | 3.465 | V |
Output Low Voltage | Vol | NA | NA | 0.4 | V |
Output High Voltage | Voh | 2.4 | NA | NA | V |
Threshold Point | Vtr+ | 1 | 1.16 | 1.34 | V |
Vtr- | 1.02 | 1.19 | 1.39 | V |
Pullup Resistor | Rpu | 26 | 46 | 71 | Kohm |
Pulldown Resistor | Rpd | 27 | 48 | 102 | Kohm |
Digital GPIO @1.8V for GPIO0/1/2/3 | Input Low Voltage | Vil | -0.3 | NA | 0.58 | V |
Input High Voltage | Vih | 1.27 | NA | 3.15 | V |
Output Low Voltage | Vol | NA | NA | 0.45 | V |
Output High Voltage | Voh | 1.40 | NA | NA | V |
Threshold Point | Vtr+ | 0.9 | 0.95 | 1.01 | V |
Vtr- | 0.91 | 0.97 | 1.03 | V |
Pullup Resistor | Rpu | 33 | 58 | 88 | Kohm |
Pulldown Resistor | Rpd | 34 | 60 | 93 | Kohm |
