楼主 |
发表于 2022-5-4 21:24:48
显示全部楼层
来自 中国江苏南京
monitor 输出信息
I (277) SPIFS: Initializing SPIFFS
I (382) SPIFS: Partition size: total: 2824001, used: 0
I (385) gpio: GPIO[0]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (392) gpio: GPIO[2]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (405) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (420) gpio: GPIO[5]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (434) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (448) gpio: GPIO[14]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (462) gpio: GPIO[16]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (477) HC595: Mvalue=ff
I (483) WINFO: wifi 2810,********** ret=0
I (489) MyCode: ESP_WIFI_MODE_STA,ssid=2810,password=************
I (500) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (513) system_api: Base MAC address is not set, read default base MAC address from EFUSE
phy_version: 1163.0, 665d56c, Jun 24 2020, 10:00:08, RTOS new
I (585) phy_init: phy ver: 1163_0
I (601) MyCodeSTA: wifi_init_sta finished.
I (723) wifi:state: 0 -> 2 (b0)
I (743) wifi:state: 2 -> 3 (0)
I (749) wifi:state: 3 -> 5 (10)
I (2009) tcpip_adapter: sta ip: 192.168.0.106, mask: 255.255.255.0, gw: 192.168.0.1:1f
I (2015) MyCodeSTA: got ip:192.168.0.106
I (2018) MyCodeSTA: connected to ap SSID:2810 password:*****************
I (2029) SNTP: Time is not set yet. Connecting to WiFi and getting time over NTP.
I (2041) SNTP: Initializing SNTP
I (2047) SNTP: Waiting for system time to be set... (1/10)
I (2057) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (2072) SNTP: Other event id:7
I (2737) SNTP: MQTT_EVENT_CONNECTED
I (2743) SNTP: sent subscribe successful, msg_id=22313
I (3042) SNTP: MQTT_EVENT_SUBSCRIBED, msg_id=22313
I (4049) SNTP: The current date/time in Shanghai is: Wed May 4 21:22:12 2022
I (5094) SNTP: MQTT_EVENT_PUBLISHED, msg_id=55148
I (7749) SNTP: MQTT_EVENT_PUBLISHED, msg_id=56520 |
