DLT2160A光发射单元是一种标准封装产品,带有连接器和光电元件,封装有LED和
驱动IC。单元的作用是将电
信号转化为光信号,通过塑料光纤传输。该单元工作在单+3V~+5V,输入信号兼容TTL。DLT2160A的最大工作速度为25Mbps。光信号通过连接器耦合到塑料光纤中。该单元具有低耗散电流、稳定光输出和高效光耦合的高性能。
• 高速信号传输(25Mbps,NRZ信号)
• 输入TTL兼容
• +3~+5V
电源
• 音频设备
• DVD播放机
• 个人电脑、笔记本电脑
• 声卡
绝对最大额定值(Ta = 25℃)
Parameter | Symbol | Rating | Unit |
Supply Voltage | Vcc | -0.5 to 7 | V |
DC Input Voltage | Vin | -0.5 to Vcc+0.5 | V |
power DisSIPation | P | 120 | mW |
Storage Temperature | Tstg | -30 to 80 | °C |
Operating Temperature | Topr | -20 to 70 | °C |
Soldering Temperature | Tsoi | 260* | °C |
电光特性
Parameter | Symbol | Conditions | MIN. | TYP. | MAX. | Unit |
Operating Voltage | Vcc | - | 2.7 | - | 5.5 | V |
Peak EMIssion Wavelength | λp | - | 640 | - | 670 | nm |
Transmission Speed | | NRZ signal | - | - | 25 | Mbps |
Transmission Distance | | Using APF* | 0.2 | - | 20 | m |
Pulse Width Distortion | △tw | 25 Mbps NRZ Signal | -11 | - | 11 | ns |
Fiber Coupling Light Output | Pf | *1 | -21 | -17 | -15 | dBm |
Dissipation current | Icc | *2 | - | 5 | 10 | mA |
High Level Input Voltage | VIH | | 2 | - | - | V |
Low Level Input Voltage | VIL | | - | - | 0.8 | V |
Rise Time | tr | *3 | - | - | 30 | ns |
Fall Time | tf | *3 | - | - | 30 | ns |
Low— High prOPAgation delay time | tPLH | *3 | - | - | 100 | ns |
Highf Low propagation delay time | tPHL | *3 | - | - | 100 | ns |
Jitter | △tj | *3 | - | 1.5 | 10 | ns |
DLT2160A_25Mbps_SPEC_118.pdf
(138.77 KB, 下载次数: 0)
