已绑定手机 已实名认证
XP015PJE120CL1B1特征:
◼ 低开关损耗
◼ 1200V 沟道场截止 IGBT
◼ 具有正温度系数的低 VCE(sat)
◼ 辅助逆变器
◼ 空调
◼ 电机驱动
◼ 不间断 电源 (UPS)
IGBT逆变器最大额定值
Symbol | Description | Conditions | Values | Unit | Vces | Collector-EMItter Voltage | Tvj=25°C | 1200 | V | Vges | Gate-Emitter Voltage | Tvj=25°C | ±20 | V | lc | Continuous DC Collector current | Tc=25°C | 30 | A | Continuous DC Collector Current | Tc=100°C | 15 | A | ICRM | Repetitive Peak Collector Current | tP=1ms | 30 | A | Ptot | Total power DisSIPation | Tc=25°C, Tvjmax=175°C | 130 | W |
IGBT逆变器特性参数:
Symbol | Description | Conditions | Values | Unit | Min. | Typ. | Max. | VF | Forward Voltage | lF=15A, Vge=0V, Tvj=25°C | — | 2.0 | 2.4 | V | lF=15A, Vge=0V, Tvj=125°C | — | 1.6 | — | V | Irm | Peak Reverse Recovery Current | lF=15A, di/dt=250A/us VR=600V, Vge=-15V Tvj=25°C | — | 10.67 | — | A | Qr | Recovered Charge | — | 1.05 | — | uC | Erec | Reverse Recovery Energy | — | 0.27 | — | mJ | Irm | Peak Reverse Recovery Current | If=15A, di/dt=250A/us Vr=600V, Vge=-15V Tvj=125°C | — | 14.31 | — | A | Qr | Recovered Charge | — | 2.95 | — | uC | Erec | Reverse Recovery Energy | — | 0.59 | — | mJ | RthJC | Thermal Resistance, Junction to Case | per Diode | — | 1.75 | 2 | K/W | RthCH | Thermal Resistance, Case to Heatsink | per IGBT Apaste=1W/(m k), AGrease=1W/(m k) | — | 1.35 | — | K/W | Tvj OP | Virtual Junction Temperature | under Switching | -40 | — | 150 | °C |
典型特征曲线
XP015PJE120CL1B1_V1.1.pdf
(697.22 KB, 下载次数: 0)
方案及技术咨询电话: 18902843661(微信同号)加号请备注
