已绑定手机 已实名认证
XP015PJS120CL1B1特征:
◼ 低开关损耗
◼ 1200V沟道场截止 IGBT
◼ 具有正温度系数的低VCE(sat)
◼ 辅助逆变器
◼ 空调
◼ 电机驱动
◼ 不间断 电源 (UPS)
IGBT逆变器
最大额定值
Symbol | Description | Conditions | Values | Unit | Vces | Collector-EMItter Voltage | Tvj=25°C | 1200 | V | Vges | Gate-Emitter Voltage | Tvj=25°C | ±20 | V | lc | Continuous DC Collector current | Tc=25°C | 30 | A | Continuous DC Collector Current | Tc=100°C | 15 | A | ICRM | Repetitive Peak Collector Current | tP=1ms | 30 | A | Ptot | Total power DisSIPation | Tc=25°C, Tvjmax=175°C | 130 | W |
特性参数
Symbol | Description | Conditions | Values | Unit | Min. | Typ- | Max. | VcE(sat) | Collector-Emitter Saturation Voltage | Vge=15V, lc=15A, Tvj=25°C | — | 1.90 | 2.30 | V | Vge=15V, lc=15A, Tvj=125°C | — | 2.40 | — | V | VGE(th) | Gate Threshold Voltage | VgeWe,Ic=480uA | 5.2 | 5.8 | 6.4 | V | Ices | Collector-Emitter Leakage Current | VCE= 1200V, VGE=0V | — | — | 1 | mA | IGES | Gate Leakage Current | Vge=±20V, Vce=0V | — | — | ±400 | nA | Qg | Total Gate Charge | VCC=960V, VGE=15V, IC=15A | — | 68 | — | nC | Cies | Input Capacitance | VCE=25V, VGE=0V, f=1MHz | — | 903 | — | pF | Cres | Reverse Transfer Capacitance | — | 48 | — | pF | td(on) | Turn-on Delay Time | VCC=600V
VGE=± 15V
IC=15A
RG=39Ω
Inductive Load
Tvj=25℃ | — | 112 | — | ns | tr | Turn-on Rise Time | — | 54 | — | ns | td(off) | Turn-off Delay Time | — | 112 | — | ns | tf | Turn-off Fall Time | — | 284 | — | ns | Eon | Turn-on Switching Loss | — | 5.18 | — | mJ | Eoff | Turn-off Switching Loss | — | 1.01 | — | mJ | td(on) | Turn-on Delay Time | VCC=600V
VGE=± 15V
IC=15A
RG=39Ω
Inductive Load
Tvj=125℃ | — | 92 | — | ns | tr | Turn-on Rise Time | — | 52 | — | ns | td(off) | Turn-off Delay Time | — | 198 | — | ns | tf | Turn-off Fall Time | — | 376 | — | ns | Eon | Turn-on Switching Loss | — | 7.93 | — | mJ | Eoff | Turn-off Switching Loss | — | 1.58 | — | mJ | ISC | SC data | Vge<15V, Vcc=600V tP<10ps, Tvj=25°C | — | 37.26 | — | A | RthJC | Thermal Resistance, Junction to Case | per IGBT | — | 1.00 | 1.15 | K/W | RthCH | Thermal Resistance, Case to Heatsink | per IGBT
λPaste=1W/(m·k), λGrease=1W/(m·k) | — | 1.05 | — | K/W | Tvj OP | Virtual Junction Temperature | under Switching | -40 | — | 150 | °C |
XP015PJS120CL1B1_V1.1.pdf
(697.57 KB, 下载次数: 0)
方案及技术咨询电话: 18902843661(微信同号)加号请备注
