LH213K-F03是一款122X250点阵TFT-
LCD模组。 该
模块由TFT LCD Panel、
驱动IC、
FPC组成。
LH213K-F03规格参数
NO. | Item | Contents | Unit |
1 | LCD Size | 2.13 | inch |
2 | display Mode | Mono TFT/Normally White/ Reflective | - |
3 | Resolution | 122(H)*250(V) | pixels |
4 | Dot pitch | 0.194(H)*0.194(V) | mm |
5 | Active area | 23.668(H)*48.5(V) | mm |
6 | Module size | 27.068(H)*56.2(V)*1.05(D) | mm |
7 | Interface | 4 Line SPI | - |
8 | Drive IC | ST7302 | - |
9 | Operating Temp. | -20℃~ + 70℃ | °C |
10 | Storage Temp. | -30℃~+ 80℃ | °C |
11 | Weight | 3.3 | g |
机械图纸
原理图
绝对最大额定参数
Parameter | Symbol | Min | MAX | Unit |
Supply Voltage (I/O) | VDD | -0.3 | 4.0 | V |
Analog Supply Voltage | IOVCC | -0.3 | 4.0 | V |
Logic Input Voltage | VIN | -0.3 | VDDIO+0.5 | V |
Operation Temperature | Top | -20 | 70 | °C |
Storage Temperature | Tst | -30 | 80 | °C |
工作条件
Parameter | Symbol | Min | TYP | MAX | Unit |
System Voltage | VDD | 2.55 | 2.8 | 3.3 | V |
Interface Operation Voltage | IOVCC | 1.65 | 1.8 | 3.3 | V |
Gate driver High Voltage | VGH | 8 | - | 13.5 | V |
Gate Driver Low Voltage | VGL | -10 | - | -5 | V |
Input voltage 'H' level | VIH | 0.7VDDI/IOVCC | - | VDDI/IOVCC | V |
Input voltage 'H' level | VIL | VSS | - | 0.3VDDI/IOVCC | V |
Output voltage 'H' level | VOH | 0.8VDDI/IOVCC | - | VDDI/IOVCC | V |
Output voltage 'L' level | VOL | VSS | - | 0.2VDDI/IOVCC | V |
SPEC LH213K-F03 VER A.pdf
(1.59 MB, 下载次数: 0)
