LM1591是一款高压降压转换器,非常适用于汽车
电源适配器电池充电器。其6.5V至32V的宽输入电压范围涵盖了汽车电池的要求,并实现了2A连续输出以实现快速充电能力。电流模式操作提供快速瞬态响应并简化环路稳定。故障保护包括逐周期电流限制和热关断。在关断模式下,转换器仅消耗20μA的电源电流。LM1591需要最少数量的现成外部组件来完成2A降压直流到直流转换器
解决方案。
•6.5V至32V宽输入工作范围
•36V绝对最大输入
•2A输出电流
•120mΩ内部功率
MOSFET开关
•稳定的低ESR输出陶瓷电容器
•高达95%的效率
•20μA关断模式
•固定300KHz频率
•热关断
•逐周期过流保护
•输出可调范围为1.22V至21V
•欠压锁定
•参考电压输出
•采用8引脚SO
IC封装
典型应用
绝对最大额定值
电源电压 VIN .....................–0.3V 至 +36V
开关电压 VSW ................. –1V 至 VIN + 0.3V
自举电压 VBS..VSW – 0.3V 至 VSW + 6V
FB、COMP 和 SS 引脚 ....................–0.3V 至 +6V
持续功耗 (TA = +25°C)
SOIC8E.................................................. ..... 2.5W
PDIP8 .................................................. ....... 1.2W
结温..........................150°C
引线温度......................................260°C
存储温度 .................... –65°C 至 +150°C
电气特性
VIN = 12V,TA = +25°C,除非另有说明
Parameter | Condition | Min | Typ | Max | Units |
Shutdown Supply current | VEN = 0V | | 20 | 35 | μA |
Supply Current | VEN = 5V, VFB = 1.4V | | 1.0 | 1.2 | mA |
Feedback Voltage | 6.5V ≤ VIN ≤ 32V, VCOMP < 2V | 1.198 | 1.222 | 1.246 | V |
Error Amplifier Voltage Gain | | | 400 | | V/V |
Error Amplifier Transconductance | ΔIC = ±10μA | 400 | 700 | 1000 | μA/V |
High-Side Switch On Resistance | | | 120 | | mΩ |
Low-Side Switch On Resistance | | | 8.5 | | Ω |
High-Side Switch Leakage Current | VEN = 0V, VSW = 0V | | 0 | 10 | μA |
Current Limit | | 2.3 | 3.6 | 5.9 | A |
Current Sense to COMP Transconductance | | | 3.5 | | A/V |
Oscillation Frequency | | 268 | 300 | 342 | KHz |
Short Circuit Oscillation Frequency | VFB = 0V | | 43 | | KHz |
Maximum Duty Cycle | VFB= 1.0V | | 90 | | % |
Minimum Duty Cycle | VFB = 1.5V | | | 0 | % |
EN Shutdown Threshold Voltage | | 0.8 | 1.2 | 1.6 | V |
enable Pull-Up Current | VEN = 0V | | 1.8 | | μA |
EN UVLO Threshold | VEN Rising | 2.4 | 2.6 | 2.7 | V |
EN UVLO Threshold Hysteresis | | | 250 | | mV |
Thermal Shutdown | | | 160 | | °C |
REF Voltage | IREF = 0 | | 5.0 | | V |
REF Load Regulation | ∆IREF = 0 to 1mA | | 100 | | mV |
REF Line Regulation | IREF = 100μA, VIN = 6.5 to 32V | | 30 | | mV |
LM1591 2A 高转换效率 开关型降压稳压器_decrypted.pdf
(434.8 KB, 下载次数: 0)
