已绑定手机 已实名认证
XD160B120BV1S3特征:
●高阻断电压,低导通电阻
●低电容高速开关
●易于并联,易于驱动
优势
●更高的系统效率
●降低冷却要求
●增加功率密度
●增加系统开关频率
● 电源
●高压DC/DC转换器
●电机驱动
● 开关电源
●脉冲电源应用
最大额定值(TC=25℃,除非另有说明)
Symbol | Parameter | Value | Unit | Test Conditions | VDSmax | Drain-Source Voltage | 1200 | V | VGS=0V, ID=100μA | VGSMax | Gate-Source Voltage | -10/+25 | V | Absolute maximum values | VgSop | Gate-Source Voltage | -5/+20 | V | Recommended operational values | Id | Continuous Drain current | 18 | A | VGS=20V, Tc=25℃ | 12 | VGS=20V, Tc=100℃ | ID(pulse) | PulSED Drain Current | 40 | A | Pulse width tp limited by TJmax | Pd | power DisSIPation | 125 | W | Tc=25℃, TJ=150℃ | Tj, Tstg | Operating Junction and Storage Temperature | -55 to +150 | °C | |
电气特性(TC=25℃,除非另有说明)
Symbol | Parameter | Min. | Typ. | Max. | Unit | Test Conditions | V(BR)DSS | Drain-Source Breakdown Voltage | 1200 | / | / | V | VGS=0V, ID=100μA | VGS(th) | Gate Threshold Voltage | 2.0 | 2.4 | 4.0 | | VDS=VGS, ID=2.5mA | / | 1.8 | / | V | Vds=Vgs, lD=2.5mA, Tj=150°C | Idss | Zero Gate Voltage Drain Current | / | 1 | 100 | µA | Vds=1200V, Vgs=0V | Igss+ | Gate-Source Leakage Current | / | 10 | 250 | nA | VDS=0V, VGS=25V | Igss- | Gate-Source Leakage Current | / | 10 | 250 | nA | Vds=0V, Vgs=-10V | RDS(on) | Drain-Source On-State Resistance | / | 160 | 196 | mΩ | Vgs=20V, Id=10A | / | 280 | / | Vgs=20V, Id=10A, Tj=150°C | Ciss | Input Capacitance | / | 890 | / | PF | VGS=0V
VDS=1000V
f=1MHz
VAC=25mV | Coss | Output Capacitance | / | 54 | / | Crss | Reverse Transfer Capacitance | / | 8.5 | / | Eoss | Coss Stored Energy | / | 31 | / | µJ | Eon | Turn-On Switching Energy | / | 315 | / | µJ | VDS=800V, VGS=-5V/20V
ID=10A, RG(ext)=2.5Ω, L=200μH | Eoff | Turn-Off Switching Energy | / | 63 | / |
XD160B120BV1S3.pdf
(1.07 MB, 下载次数: 0)
方案及技术咨询电话: 18902843661(微信同号)加号请备注
