SL484特征
●30V/41A,
RDS(ON)=14mW(最大值)@ VGS=10V
RDS(ON)=20mW(最大值)@ VGS=4.5V
●可靠坚固
●提供无铅和绿色设备(符合RoHS)
绝对最大额定值(TA = 25° C,除非另有说明)
Symbol | Parameter | Rating | Unit |
Common Ratings (TA=25°C Unless Otherwise Noted) |
Vdss | Drain-Source Voltage | 30 | V |
Vgss | Gate-Source Voltage | ±20 |
Tj | Maximum Junction Temperature | 150 | °C |
Tstg | Storage Temperature Range | -55 to 150 |
IS | Diode Continuous Forward current | Tc=25°C | 20 | A |
ID | Continuous Drain Current | Tc=25°C | 41 |
Tc=100°C | 26 |
IDM | PulSED Drain Current | Tc=25°C | 103 |
Pd | Maximum power DisSIPation | Tc=25°C | 35.7 | W |
Tc=100°C | 14.3 |
RθJC | Thermal Resistance-J unction to Case | Steady State | 3.5 | °C/W |
ID | Continuous Drain Current | Ta=25°C | 12.2 | A |
Ta=70°C | 9.8 |
Pd | Maximum Power Dissipation | Ta=25°C | 3.1 | W |
Ta=70°C | 2.0 |
RθJA | Thermal Resistance-J unction to Ambient | t ≤10s | 17 | °C/W |
Steady State | 40 |
IAS | Avalanche Current, Single pulse (L=0.1mH) | 19 | A |
EAS | Avalanche Energy, Single pulse (L=0.1mH) | 18 | mJ |
电气特性(TA = 25° C,除非另有说明)
Symbol | Parameter | Test Conditions | Min. | Typ. | Max. | Unit |
Static Characteristics |
BVdss | Drain-Source Breakdown Voltage | Vgs=0V, Ids=250μA | 30 | - | - | V |
Idss | Zero Gate Voltage Drain Current | Vds=24V, Vgs=0V | - | - | 1 | μA |
| Tj=85°C | - | - | 30 |
VGS(th) | Gate Threshold Voltage | Vds=Vgs, Ids=250μA | 1 | 1.65 | 2 | V |
Igss | Gate Leakage Current | Vgs=±20V, VDs=0V | - | - | ±100 | nA |
RDS(ON) | Drain-Source On-state Resistance | Vgs=10V, Ids=20A | - | 11.5 | 14 | mΩ |
| Tj=125°C | - | 16.4 | - |
Vgs=4.5V, IDs=10A | - | 14.5 | 20 |
Gfs | Forward Transconductance | Vds=5V , Id=15A | - | 24 | - | S |
SL484 30V41A 14毫欧TO-252.pdf
(776.81 KB, 下载次数: 0)
