QCN9074 QCN9024 QCN6024 802.11ax 4x4 2.4GHz
wifi6
Qualcomm Atheros QCN9074
■ 2.4GHz, max 23dBm per chain, up to 1147Mbps
■ Single Band 2.4GHz 4x4 WiFi 6 (802.11ax
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to 70
ºC
Storage Temperature Range
-40 to 90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware
SPECifications
Symbol
Parameter
Chipset
WLAN Host Interface
System
memory
2Mbit serial I²C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
Q
SDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
2.412GHz-2.472GHz
Data Rates for WALN
2.4GHz, max 23dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN
support 20/40MHz at 2.4GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
power Consumption
TBD
Reference Design
PN01.1
Dimensions (WxHxD)
57mm x 63mm x 6mm
M.2 Pin Definitions
Pin No. Name Pin No. Name
1
GND
2
VDD3P3_PCIE
3
4
VDD3P3_PCIE
5
6
PCIE_LED0
7
GND
8
GPIO46_WCI2_
UART_TXD_PCIE
9
TP19
10
GPIO47_WCI2_UART_RXD_PCIE
11
12
13
14
15
VDD_XPA_PCIE
16
PCIE_LED1
17
VDD_XPA_PCIE
18
GND
19
VDD_XPA_PCIE
20
21
VDD_XPA_PCIE
22
23
VDD_XPA_PCIE
33
GND
32
35
PCIE0_RX0_P
34
37
PCIE0_RX0_N
36
39
GND
38
MOD_BT_STS_2
41
PCIE0_TX0_P
40
MOD_WL_ACT_2
43
PCIE0_TX0_N
42
PINE_BT_ACT_2
45
GND
44
MOD_BT_STS
47
PCIE0_REFCLK_P
46
MOD_WL_ACT
49
PCIE0_REFCLK_N
48
PINE_BT_ACT
51
GND
50
53
PCIE0_CLKREQ_3P3_N
52
PCIE0_PERST_3P3
55
PCIE0_WAKE_3P3_N
54
57
GND
56
59
PCIE0_RX1_P
58
61
PCIE0_RX1_N
60
63
GND
62
65
PCIE0_TX1_P
64
67
PCIE0_TX1_N
66
69
GND
68
71
70
73
72
VDD3P3_PCIE
75
GND
74
VDD3P3_PCIE
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication
products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult.
