●30V/88A,
-RDS(ON)=8.5mW(最大值)@VGS=10V
-RDS(ON)=12mW(最大值)@VGS=4.5V
●提供卓越的Qgd x Rds-on
●100% UIS+Rg测试
●可靠坚固
●提供无铅和绿色设备(符合RoHS)
绝对最大额定值(TA=25°C,除非另有说明)
Symbol | Parameter | Rating | Unit |
Common Ratings |
Vdss | Drain-Source Voltage | 30 | V |
Vgss | Gate-Source Voltage | ±20 |
Tj | Maximum Junction Temperature | 150 | °C |
Tstg | Storage Temperature Range | -55 to 150 |
Is | Diode Continuous Forward current | Tc=25°C | 20 | A |
Id | Continuous Drain Current | Tc=25°C | 88 |
Tc=100°C | 31 |
Idm | PulSED Drain Current | Tc=25°C | 123 |
Pd | Maximum power DisSIPation | Tc=25°C | 31 | W |
Tc=100°C | 12.5 |
Rθjc | Thermal Resistance-Junction to Case | Steady State | 3.9 | °C/W |
Id | Continuous Drain Current | Ta=25°C | 14.4 | A |
Ta=70°C | 11.6 |
Pd | Maximum Power Dissipation | Ta=25°C | 2.7 | W |
Ta=70°C | 1.7 |
RθJA | Thermal Resistance-Junction to Ambient | t≤10s | 20 | °C/W |
Steady State | 47 |
lAs | Avalanche Current, Single pulse | L=0.1mH | 20 | A |
EAs | Avalanche Energy, Single pulse | L=0.1mH | 20 | mJ |
电气特性(TA = 25° C,除非另有说明)
Symbol | Parameter | Test Conditions | Min. | Typ. | Max. | Unit |
Static Characteristics |
BVdss | Drain-Source Breakdown Voltage | VGs=0V, IDs=250μA | 30 | - | - | V |
BVDsst | Drain-Source Breakdown Voltage (transient) | VGS=0V, ID(aval)=15A
Tcase=25°C,ttransient=100ns | 34 | - | - | V |
Idss | Zero Gate Voltage Drain Current | Vds=24V, Vgs=0V | - | - | 1 | μA |
| Tj=85°C | - | - | 30 |
VGS(th) | Gate Threshold Voltage | Vds=Vgs, Ids=250卩A | 1.5 | 1.8 | 2.5 | V |
Igss | Gate Leakage Current | Vgs=±20V, Vds=0V | - | - | ±100 | nA |
Rds(on) | Drain-Source On-state Resistance | VGS=10V, lDS=20A | - | 7 | 8.5 | mΩ |
| Tj=125°C | - | 10.5 | - |
Vgs=4.5V, Ids=10A | - | 9.2 | 12 |
Gfs | Forward Transconductance | Vds=5V, Ids=10A | - | 40 | - | S |
