SL3402是N沟道逻辑增强模式功率场效应
晶体管,采用高单元密度先进沟槽技术生产。这种高密度工艺专门用于最大限度地降低通态电阻。这些器件特别适用于低电压应用,并且在外形非常小的表面贴装封装中需要低在线功率损耗。
●30V/4.0A, RDS(ON)=40mΩ (typ.)@VGS=10V
●30V/3.0A, RDS(ON)=45mΩ (typ.)@VGS=4.5V
●30V/2.0A, RDS(ON)=60mΩ (typ.)@VGS=2.5V
●超高设计,极低 RDS(ON)
●卓越的导通电阻和最大直流电流能力
●完全符合 RoHS
●SOT23封装设计
电源管理
●便携式设备
●DC/DC转换器
●负荷开关
●DSC
LCD显示逆变器
绝对最大额定值(TA = 25℃ 除非另有说明)
Symbol | Parameter | Typical | Unit |
Vdss | Drain-Source Voltage | 30 | V |
Vgss | Gate-Source Voltage | ±12 | V |
Id | Continuous Drain current (TJ=150°C) | Vgs 4.5V | 4 | A |
IDM | PulSED Drain Current | 15 | A |
Is | Continuous Source Current (Diode Conduction) | 1.5 | A |
Pd | power DisSIPation | Ta=25°C | 1.4 | W |
Ta=70°C | 0.9 |
Tj | Operation Junction Temperature | 150 | °C |
Tstg | Storage Temperature Range | -55~+150 | °C |
RθJA | Thermal Resistance Junction to Ambient | 90 | °C/W |
电气特性(TA=25℃ 除非另有说明)
Symbol | Parameter | Condition | Min | Typ | Max | Unit |
Static Parameters |
V(BR)DSS | Drain-Source Breakdown Voltage | VGS=0V, Id=250uA | 30 | | | V |
VGS(th) | Gate Threshold Voltage | Vds=Vgs, Id=250uA | 0.5 | | 1.5 | V |
Igss | Gate Leakage Current | Vds=0V, Vgs=±12V | | | ±100 | nA |
Idss | Zero Gate Voltage Drain Current | Vds=30V, Vgs=0 | | | 1 | uA |
Vds=30V, Vgs=0 Tj=55°C | | | 5 |
Rds(on) | Drain-Source On-Resistance | VGS=10V, Id=4.0A | | 40 | 50 | mΩ |
Vgs=4.5V, Id=3.0A | | 45 | 65 |
Vgs=2.5V, Id=2.0A | | 60 | 85 |
