NCP1247是一款具有动态自供电功能的新型固定频率电流模式
控制器。此功能通过激活内部启动电流源在启动、瞬态、锁存、待机等期间为控制器供电,极大地简化了辅助
电源和VCC电容器的设计。该器件包含一个特殊的HV检测器,用于检测应用从交流输入线上拔下并触发X2放电电流。这种HV结构还允许进行掉电检测。它具有基于定时器的故障检测功能,可确保检测到过载和可调补偿,以帮助保持最大功率独立于输入电压。由于频率折返,控制器表现出在轻负载条件下具有出色的效率,同时仍可实现非常低的待机功耗。内部频率抖动、斜坡补偿和通用锁存输入使该控制器成为稳健电源设计的理想选择。专用关闭模式允许通过“休眠”整个设备达到极低的空载输入功耗,从而最大限度地减少控制电路的功耗。
•固定频率电流模式操作(65kHz和100kHz频率选项)
•频率折返然后跳跃模式可在轻负载和待机条件下实现最大性能
•基于定时器的过载保护,具有锁存(选项A/C)或自动恢复(选项B/D)操作
•具有欠压检测和动态自供电的高压电流源,简化了VCC电路的设计
•用于软化
EMI特征的频率调制
•取决于大电压的可调过功率保护
•闭锁输入与过功率保护检测输入相结合
•VCC工作电压高达28V,具有过压检测功能
•500/800mA拉电流/灌电流驱动峰值电流能力
•10ms软启动
•内部热关断
•空载待机功率<30mW
•EMI滤波器放电功能中的X2电容器
•这些器件不含铅和卤素/BFR
典型应用
•适用于笔记本电脑、
LCD和打印机的AC-DC适配器
•离线电池充电器
•消费电子电源
•辅助/内务电源
•笔记本离线适配器
典型应用示例
最高额定值
Rating | Symbol | Value | Unit |
DRV (Pin 5) | Maximum voltage on DRV pin (Dc-current self-limited if operated within the allowed range) (Note 1) | -0.3 to 20 ±1000 (peak) | V mA |
Vcc (Pin 6) | Vcc power Supply voltage, Vcc pin, continuous voltage Power Supply voltage, Vcc Pin, continuous voltage (Note 1) | -0.3 to 28 ±30 (peak) | V mA |
HV (Pin 8) | Maximum voltage on HV pin (Dc-Current self-limited if operated within the allowed range) | -0.3 to 500 ±20 | V mA |
Vmax | Maximum voltage on low power pins (except pin 5, pin 6 and pin 8) (Dc-Current self-limited if operated within the allowed range) (Note 1) | -0.3 to 10 ±10 (peak) | V mA |
RθJ−A | Thermal Resistance SOIC−7
Junction-to-Air, low conductivity PCB (Note 2)
Junction-to-Air, medium conductivity PCB (Note 3)
Junction-to-Air, high conductivity PCB (Note 4) | 162
147
115 | °C/W |
RθJ-C | Thermal Resistance Junction-to-Case | 73 | °C/W |
Tjmax | Operating Junction Temperature | -40 to +150 | °C |
Tstrgmax | Storage Temperature Range | -60 to +150 | °C |
| ESD Capability, HBM model (All pins except HV) per J EDEC Standard JESD22, Method A114E | >2000 | V |
| ESD Capability, Machine Model per JEDEC Standard JESD22, Method A115A | >200 | V |
| ESD Capability, Charged device Model per JEDEC Standard JESD22, Method C101D | > 1000 | V |
