ULC0524PL特征:
●超低电容:0.2pF 典型值(I/O 到 I/O)
●超低泄漏:nA 级
●工作电压:5V
●低钳位电压
●多达 4 条线路保护
●无铅流通封装
●符合以下标准:
– IEC 61000-4-2 (
ESD) 抗扰度测试
空气放电:±20kV
接触放电:±15kV
– IEC61000-4-5(闪电)4A(8/20μs)
●符合 RoHS 标准
HDMI 1.3/1.4/2.0、USB 2.0/3.0 和 MDDI
端口
●显示器和平板显示器
机顶盒和数字电视
视频显卡
●数字视频接口 (DVI)
●笔记本电脑
●PCI Express 和串行
SATA 端口
机械特性
●封装:DFN2510-10 (2.5×1.0×0.5mm)
●铅表面处理:雾锡
●外壳材料:“绿色”模塑料。
●湿度敏感性:根据 J-STD-020 3 级
●端子连接:见下图
●标记信息:见下文
绝对最大额定值(Tamb=25°C,除非另有说明)
Parameter | Symbol | Value | Unit |
Peak Pulse power (8/20μs) | Ppp | 60 | W |
ESD per IEC 61000-4-2 (Air) | Vesd | ± 20 士 15 | Kv |
ESD per IEC 61000-4-2 (Contact) |
Operating Temperature Range | Tj | -55 to+125 | °C |
Storage Temperature Range | Tstj | -55 to+150 | °C |
电气特性(TA=25°C,除非另有说明)
Parameter | Symbol | Min | Typ | Max | Unit | Test Condition |
Reverse Working Voltage | VRwm | | | 5 | V | Any I/O pin to ground |
Breakdown Voltage | Vbr | 6 | | | V | It = 1mA, any I/O pin to ground |
Reverse Leakage current | Ir | | | 0.5 | μA | Vrwm = 5V, any I/O pin to ground |
Clamping Voltage | vc | | | 10 | V | Ipp = 1A (8 x 20ps pulse), any I/O pin to ground |
Clamping Voltage | VC | | | 15 | V | Ipp = 4A (8 x 20ps pulse), any I/O pin to ground |
Junction Capacitance | Cj | | 0.2 | 0.3 | pF | VR = 0V, f = 1MHz, between I/O pins |
Junction Capacitance | Cj | | | 0.5 | pF | VR = 0V, f = 1MHz, any I/O pin to ground |
典型性能特征(TA=25°C,除非另有说明)
DFN2510-10_ULC0524PL.pdf
(4.14 MB, 下载次数: 0)
