SL3406特征
·30V/4.0A,
-RDS(ON)=50mW(最大值)@VGS=10V
-RDS(ON)=70mW(最大值)@VGS=4.5V
·可靠坚固
·提供无铅和绿色设备(符合RoHS)
·笔记本电脑、便携式设备和电池供电系统中的
电源管理。
·负荷开关
绝对最大额定值(TA = 25° C,除非另有说明)
Symbol | Parameter | Rating | Unit |
Vdss | Drain-Source Voltage | 30 | V |
Vgss | Gate-Source Voltage | ±20 |
Id | Continuous Drain current | Ta=25°C | 4.0 | A |
Ta=70°C | 3.7 |
IDM | 300卩s PulSED Drain Current | VGS=10V | 18 |
Is | Diode Continuous Forward Current | 1 | A |
Tj | Maximum Junction Temperature | 150 | °C |
Tstg | Storage Temperature Range | -55 to 150 |
Pd | Maximum power DisSIPation | Ta=25°C | 1.4 | W |
Ta=70°C | 0.9 |
RθJA | Thermal Resistance-Junction to Ambient | t ≤10sec | 90 | °c/w |
Steady state | 140 |
电气特性(TA = 25° C,除非另有说明)
Symbol | Parameter | Test Conditions | | Unit |
Min. | Typ. | Max. |
Static Characteristics |
BVdss | Drain-Source Breakdown Voltage | Vgs=0V, Ids=250μA | 30 | . | . | V |
Idss | Zero Gate Voltage Drain Current | Vds=24V, Vgs=0V | . | . | 1 | μA |
Tj=85°C | . | . | 30 |
Vcs(th) | Gate Threshold Voltage | VDS=VGS, IDS=250μA | 1.3 | 1.8 | 2.5 | V |
Igss | Gate Leakage Current | Vgs=±20V, Vds=0V | . | . | ±100 | nA |
RDS(ON) | Drain-Source On-St ate Resistance | VGS=10V, IDS=4A | . | 36 | 50 | mΩ |
Vgs=4.5V, Ids=3A | . | 49 | 70 |
Diode Characteristics |
VSD | Diode Forward Voltage | ISD=1A, VGS=0V | . | 0.75 | 1.1 | V |
trr | Reverse Recovery Time | ISD=4A, dlSD/dt=100A/μs | . | 10 | . | ns |
Qrr | Reverse Recovery Charge | . | 4 | . | nC |
SL3406 30V4A 50毫欧 SOT23-3L.pdf
(894.72 KB, 下载次数: 0)
