L
M350是一款可调三端正电压调节器,能够在1.2V至33V的输出电压范围内提供超过3.0A的电流。该电压调节器非常易于使用,仅需两个外部电阻器即可设置输出电压.此外,它采用内部电流限制、热关断和安全区域补偿,使其本质上是防熔断的。LM350服务于各种应用,包括本地、卡上调节。该器件还制作了一个特别简单的可调开关稳压器、可编程输出稳压器,或者通过在调整和输出之间连接一个固定电阻,LM350可以用作精密电流稳压器。
•保证3.0A输出电流
•输出可在1.2V和33V之间调节
•负载调节率通常为0.1%
•线路调整率通常为0.005%/V
•内部热过载保护
•内部短路电流限制常数随温度变化
•输出
晶体管安全区域补偿
•高压应用的浮动操作
•标准3引脚晶体管封装
•无需储存许多固定电压
最高额定值
Rating | Symbol | Value | Unit |
Input-Output Voltage Differential | VI–VO | 35 | Vdc |
power DisSIPation | Pd | Internally Limited | W |
Operating Junction Temperature Range | Tj | -40 to +125 | °C |
Storage Temperature Range | Tstg | -65 to +150 | °C |
Soldering Lead Temperature (10 seconds) | Tsolder | 300 | °C |
电气特性
Characteristics | Figure | Symbol | Min | Typ | Max | Unit |
Line Regulation (Note 2)
TA = 25°C, 3.0 V ≤ VI–VO ≤ 35 V | 1 | Regline | — | 0.0005 | 0.03 | %/V |
Load Regulation (Note 2)
TA = 25°C, 10 mA ≤ Il ≤ 3.0 A
VO ≤ 5.0 V
VO ≥ 5.0 V | 2 | Regioad | — | 5.0
0.1 | 25
0.5 | mV
% VO |
Thermal Regulation, Pulse = 20 ms,
(TA = +25°C) | | Regtherm | — | 0.002 | — | %v(yw |
Adjustment Pin current | 3 | IAdj | — | 50 | 100 | μA |
Adjustment Pin Current Change
10 mA ≤ IL ≤ 3.0 A, PD ≤ Pmax | 1,2 | ∆IAdj | — | 0.2 | 5.0 | μA |
Reference Voltage
10 mA ≤ IO ≤ 3.0 A, PD ≤ Pmax | 3 | VRef | 1.20 | 1.25 | 1.30 | V |
3.0 V ≤ VI–VO ≤ 35 V | 1 | Regime | — | 0.02 | 0.07 | %/V |
10 mA ≤ IL ≤ 3.0 A
VO ≤ 5.0 V
VO ≥ 5.0 V | 2 | Regioad | — | 20
0.3 | 70
1.5 | mV
% VO |
