Codec (FOURCC) | Profile / Level | Resolution | Frame Rate (fps) | Bit Rate (Mbps) |
HEVC | High Efficiency Video Coding (hevc, hvc1,hev1) | High Profle@Level 4.1 | 1440x 1080 (MaxDpbSize 8) 1920x1080 ((MaxDpbSize 6) | 30 | 30 |
MPEG | MPEG-1 Part2-Video |
| 1920x1080 | 30 | 4 #Base on available file |
MPEG-2 Part2-Video H.262 | Main Profile@High Level | 1920x1080 | 30 | 30 |
MPEG-4 Part 2-Visual | Simple Profile (SP) @ Level 3 | CIF (352x240,352x288) QCIF (176x144) | 30 | 30 |
Advanced Sinple Profile (ASP) @ Level 5 | 720576 | 30 | 8.3 #Base on avaiable file |
MPEG-4 Part10-AVC H.264 (X264) | Baseline Profile@Level 3.1 | 960 x 720 (Max Ref frame 20) 1280 x 720 (Max Ref frame 9) | 30 | 17.9 #Base on available file |
Main Profile@Level 4.1 | 1280 x 960 (Max Ref frame 6) | 30 | 30 |
High Profile®Level 4.1 | 1440 x 1080 (Max Ref frame 5) 1920 x 1080 (Max Ref frame 4) | 30 | 30 |
Microsoft | VC-1 | Advanced Profile @ Level 3 | 1920x1080 | 30 | 30 |
WMV9 (WMV3, WVC1) | Simple / Main profile (WMV3) @ High VC-1 simple/main profile compliant | 1920x1080 | 30 | 15 #Base on available file |
Advanced Profile (WVC1) @ Level 3 VC-1 advanced profile compliant | 1920x1080 | 30 | 20 |
Microsoft ISO MPEG-4 version 3 (MP43) |
| 1920x1080 | 30 | 2.5 #Base on available file |
DivX (support 2-point GMC) | DivX3 (DIV3, DIV4, DIV5, DIV6) DivX4 (DIVX), DivX5 (DX50) | HD Profile MPEG- 4 ASP compliant | 1920x1080 | 30 | 20 |
Xvid (support 2-point GMC) | Xvid (XVID) | MPEG- 4 ASP compliant | 1920x1080 | 30 | 30 |
RealVideo | RealVideo 8 (RV30) RealVideo 9 / RealVideo 10 (RV40) |
| 19201080 | 30 | 4.7 #Base on available file |
H.263 | Sorenson H.263 (FLV1) |
| 1920x1080 | 30 | 1.9 #Base on available file |
Motion JPEG | M-JPEG (MJPG) (non-support interlaced mode) |
| 1280x720 | 30 | 10 |
AVS | Audio Video coding Standard (AVS) | Jizhun profile | 1920x1080 | 30 | 14.5 #Base on available file |
AVS+ | Audio Video coding Standard plus (AVS+) | broadcasting profile Jizhun profile | 1920x1080 | 30 | 12 #Base on available file |
