CDBHD120L/CDBHD1100L特征:
- 桥中的低 Vf 肖特基势垒
芯片
- 带保护环的金属-半导体结
- 高浪涌电流能力
- 硅外延平面芯片
- 用于低压、高效逆变器、续流和极性保护应用
- 无铅部分,符合RoHS要求
机械参数
- 外壳:Mini-Dip 桥 (TO-269AA) 塑料模制外壳
- 环氧树脂:UL94-V0 级阻燃
- 端子:根据 MIL-STD-750 方法 2026 可焊接
- 极性:如身体标记
- 安装位置:任意
- 重量:0.0078 ounces, 0.22 grams
最大额定值和电气特性
Parameter | Symbol | CDBHD120L-G | CDBHD140L-G | CDBHD160L-G | CDBHD180L-G | CDBHD1100L-G | Units |
Maximum repetitive peak reverse voltage | Vrrm | 20 | 40 | 60 | 80 | 100 | V |
Maximum DC blocking voltage | Vdc | 20 | 40 | 60 | 80 | 100 | V |
Maximum RMS voltage | Vrms | 14 | 28 | 42 | 56 | 70 | V |
Peak surge forward current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) | Ifsm | 30.0 | A |
Max. average forward current 0.2*0.2"(5.0*5.0mm)copper pad area,see Figure 1 | Iw | 1.0 | A |
Max. instantaneous forward voltage at 1.0A(Note 1) | Vf | 0.44 | 0.625 | 0.75 | V |
Max. DC reverse current at rated DC blocking voltage | Ta=25°C | Ir | 0.50 | mA |
Ta=100°C | Ir | 20.0 |
Typical junction Capacitance (Note 2) | Cj | 250 125 | pF |
Typical thermal resistance (Note 3) | Rqja Rqjl | 85.0 20.0 | °C/W |
Operating junction temperature Range | Tj | -55 to+125 | °C |
Storage temperature Range | Tstg | -55 to +150 | °C |
额定值和特性曲线(CDBHD120L-G至CDBHD1100L-G)
CDBHD1100L.pdf
(159.15 KB, 下载次数: 0)
