NCP1615是一款高压PFC控制器,设计用于基于创新的电流控制频率折返(CCFF)方法驱动PFC升压级。在此模式下,当电感器电流超过可编程值时,电路以临界导通模式(CrM)运行。当电流低于此预设水平时,NCP1615在正弦过零处将频率线性衰减至最低约26kHz。CCFF在标称负载和轻负载下都能最大限度地提高效率。特别是,待机损耗降至最低。即使开关频率降低,创新的电路也允许接近统一的功率因数。集成的高压启动电路消除了对外部启动组件的需求,并且在正常运行期间消耗的功率可以忽略不计。NCP1615采用SOIC-14或SOIC-16封装,具有强大且紧凑的PFC级所需的功能,且外部组件很少。
一般特征
•具有集成欠压检测的高压启动电路
•强制控制器进入待机模式的输入
•重启引脚允许在待机模式下调整大电压滞后
•过零线附近的跳过模式
•快速线路/负载瞬态补偿
•谷底切换以提高效率
•高驱动能力:−500mA/+800mA
•宽VCC范围:9.5V至28V
•输入电压范围检测
•输入X2电容放电电路
•省电模式(PSM)可实现<30mW空载功耗
•这是一款无铅无卤素设备
安全特性
•可调大容量欠压检测(BUV)
•软过压保护
•线路过压保护
•过流保护
•FB和F
OVP/BUV引脚的开路引脚保护
•内部热关断
•用于OVP和OTP的双电平锁存输入
•旁路/升压
二极管短路保护
•开路接地引脚保护
最大额定值
Rating | Pin | Symbol | Value | Unit |
High Voltage Start-Up Circuit Input Voltage | HV | VHV | -0.3 to 700 | V |
High Voltage Feedback Input Voltage | HVFB | VHVFB | -0.3 to 700 | V |
High Voltage Feedback Input Current | HVFB | IHVFB | 0.5 | mA |
Zero Current Detection and Current Sense Input Voltage (Note 10) | CS/ZCD | VCS/ZCD | −0.3 to VCS/ZCD(MAX) | V |
Zero Current Detection and Current Sense Input Current | CS/ZCD | ICS/ZCD | +5 | mA |
Control Input Voltage (Note 11) | Control | Vcontrol | −0.3 to VControl(MAX) | V |
Supply Input Voltage | VCC | VcC(MAX) | -0.3 to 28 | V |
Fault Input Voltage | Fault | VFault | −0.3 to (VCC + 0.6) | V |
PSTimer Input Voltage | PSTimer | VPSTimer | −0.3 to (VCC + 0.6) | V |
Driver Maximum Voltage (Note 12) | DRV | Vdrv | -0.3 to Vdrv | V |
Driver Maximum Current | DRV | IDRV(SRC)
IDRV(SNK) | 500
800 | mA |
Maximum Input Voltage (Note 13) | Other Pins | VMAX | -0.3 to 7 | V |
Maximum Operating Junction Temperature | | Tj | -40 to 150 | °C |
Storage Temperature Range | | Tstg | -60 to 150 | °C |
Lead Temperature (Soldering, 10 s) | | TL(MAX) | 300 | °C |
Moisture Sensitivity Level | | MSL | 1 | — |
