新的MDmeshM6技术融合了SJ MOSFET著名且整合的MDmesh系列的最新进展。STMicroelectronics通过其新的M6技术在上一代MDmesh器件的基础上构建,该技术结合了出色的每面积RDS(on)改进与可用的最有效开关行为之一,以及用户友好的体验,以最大限度地提高最终应用效率。
STL19N60M6特点:
• 降低开关损耗
• 与上一代相比,每个区域的 RDS(on) 更低
• 低栅极输入电阻
• 100% 雪崩测试
• 齐纳保护
• 切换应用程序
• LLC 转换器
• 升压 PFC 转换器
绝对最大额定值
Symbol | Parameter | Value | Unit |
VGS | Gate-source voltage | ±25 | V |
ID | Drain current (continuous) at Tc = 25 °C | 11 | A |
Drain current (continuous) at Tc = 100 °C | 6.9 | A |
IDM | Drain current (pulsed) | 38 | A |
PTOT | Total power dissipation at Tc = 25 °C | 90 | W |
dv/dt | Peak diode recovery voltage slope | 15 | V/ns |
dv/dt | MOSFET dv/dt ruggedness | 100 | V/ns |
Tstg | Storage temperature range | -55 to 150 | °C |
Tj | Operating junction temperature range |
电气特性
Symbol | Parameter | Test conditions | Min. | Typ. | Max. | Unit |
V(BR)DSS | Drain-source breakdown voltage | VGS = 0 V, ID = 1 mA | 600 | | | V |
IDSS | Zero gate voltage drain current | VGS = 0 V, VDS = 600 V | | | 1 | µA |
VGS = 0 V, VDS = 600 V, TC = 125 °C | | | 100 | µA |
IGSS | Gate-body leakage current | VDS = 0 V, VGS = ±25 V | | | ±5 | µA |
VGS(th) | Gate threshold voltage | VDS = VGS, ID = 250 µA | 3.25 | 4 | 4.75 | V |
RDS(on) | Static drain-source on-resistance | VGS = 10 V, ID = 6.5 A | | 255 | 308 | mΩ |
TC = 25 °C 除非另有说明
On/off states
stl19n60m6.pdf
(570.45 KB, 下载次数: 0)
