NCP3020是一款PWM器件,设计用于在宽输入范围内工作,能够产生低至0.6V的输出电压。NCP3020提供集成栅极驱动器和内部设置的300kHz(NCP3020A)或600kHz(NCP3020B)振荡器.NCP3020还具有外部补偿跨导误差放大器和内部固定软启动。保护功能包括无损电流限制和短路保护、输出过压保护、输出欠压保护和输入欠压锁定。NCP3020目前采用SOIC−8封装。
•输入电压范围为4.7V至28V
•300kHz操作(NCP3020B–600kHz)
•0.6V内部参考电压
•内部编程6.8ms软启动(NCP3020B–4.4ms)
•电流限制和短路保护
•带外部补偿的跨导放大器
•输入欠压锁定
•输出过压和欠压检测
•用于需要现场和变更控制的汽车和其他应用的NCV前缀
绝对最大额定值
Rating | Symbol | Vmax | Vmin | Unit |
High Side Drive Boost Pin | BST | 45 | -0.3 | V |
Boost to Vsw differential voltage | BST-Vsw | 13.2 | -0.3 | V |
COMP | COMP | 5.5 | -0.3 | V |
Feedback | FB | 5.5 | -0.3 | V |
High-Side Driver Output | HSDR | 40 | -0.3 | V |
Low-Side Driver Output | LSDR | 13.2 | -0.3 | V |
Main Supply Voltage Input | VCC | 40 | -0.3 | V |
Switch Node Voltage | Vsw | 40 | -0.6 | V |
Maximum Average Current Vcc, BST, HSDRV, LSDRV, Vsw, GND | Imax | 130 | mA |
Operating Junction Temperature Range (Note 1) | Tj | -40 to+140 | °C |
Maximum Junction Temperature | Tj(MAX) | +150 | °C |
Storage Temperature Range | Tstg | -55 to+150 | °C |
Thermal Characteristics (Note 2) SOIC-8 Plastic Package Thermal Resistance Junction-to-Air | RθJA | 165 | °C/W |
Lead Temperature Soldering (10 sec): Reflow (SMD styles only) Pb-Free (Note 3) | Rf | 260 Peak | °C |
电气特性(−40°C < TJ < +125°C,VCC = 12 V,对于最小值/最大值,除非另有说明)
Characteristic | Conditions | Min | Typ | Max | Unit |
Input Voltage Range | — | 4.7 | | 28 | V |
Vcc Supply Current NCP3020A | VFB = 0.55 V, Switching, VCC = 4.7 V | — | 5.5 | 8.0 | mA |
VFB = 0.55 V, Switching, VCC = 28 V | — | 7.0 | 11 | mA |
Vcc Supply Current NCP3020B | VFB = 0.55 V, Switching, VCC = 4.7 V | — | 5.9 | 10 | mA |
VFB = 0.55 V, Switching, VCC = 28 V | — | 7.8 | 13 | mA |
UVLO Rising Threshold | VCC Rising Edge | 4.0 | 4.3 | 4.7 | V |
UVLO Falling Threshold | VCC Falling Edge | 3.5 | 3.9 | 4.3 | V |
