S5K3L2XX CIS 可通过 CCI 或 SPI 串行接口进行编程,并包括片上一次性可编程 (OTP) 非易失性存储器 (NVM)。
S5K3L2XX适用于2.8 V/1.2 V电源的低功耗摄像头模组。
13Mp sensor with 1/3.06"optics
Pixel size: 1.12 μm
Effective resolution: 4208 (H) * 3120 (V)
Electronic rolling shutter and global reset
Support digital video stabilization margins in main view modes
Frame rate:
- Capture: 13M-4:3 30 fps (3939 Mbps)
- FHD video: 10M-16:9 30 fps (2990 Mbps) / 2.7M (16:9) 60 fps (1494 Mbps)
- HD video: 1.5M-16:9 100 fps
- High speed: QVGA 240 fps
Interfaces:
- Fine interface frequency control using additional dedicated PLL for EMI avoidance and integration flexibility.
- MIPI CSI2 – four lanes (1Gbps per lane)
- 10-bit parallel video interface, with reduced frame rate
- Output formats: RAW8 (using DPCM/PCM compression), RAW10, RAW12 (for test only)
Control interface:
- SPI interface – Three-wire serial communication circuit up to 18 MHz.
- I2C-compatible – Two-wire serial communication circuit up to 400 kHz.
Xenon/LED flash
Mechanical shutter
8 Kbit on-chip OTP memory to support defect corrections & chip ID.
Analog gain x16
Vertical and horizontal flip mode
Continuous frame capture mode
2/2, 4/4, x3 V – average/average-sub-sampling readout
Pixel elimination readout function
x2, x3, x4 Bayer downscaler function
Bad pixel correction
On-chip temperature sensor
Built-in test pattern generation
Supply voltage: 2.8 V for analog and 2.8 V or 1.8 V for I/O, 1.2 V for digital core supply
Operating temperature: – 30 ℃ to + 70 ℃
