Features ■ 6GHz, max 23dBm per chain, up to 4949Mbps ■ Single Band 6GHz 4×4 WiFi 6E (802.11ax) ■ 4 spatial streams (4SS) ■ M.2 E Key Interface ■ PCI Express 3.0 Interface Wallys Communications (Suzhou ) Co., LTD
Email:sales1@wallystech.com
Parameter | Rating | Unit | Operating Temperature Range | -20 to 70 | ºC | Storage Temperature Range | -40 to 90 | ºC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol
| Parameter
| Chipset
| Qualcomm Atheros QCN9074
| WLAN Host Interface
| System Memory
| 2Mbit serial I²C bus EEPROM
| Standard Operating Voltage
| 5V
| Operating Systems
| QSDK
| Host Interface
| M.2 E Key
| Antenna Cable / Port
| 4 x MMCX Connectors,4T4R
| Frequency Range
| 5.925GHz-7.125GHz
| Data Rates for WALN
| Channel Spectrum Widths for WLAN
| Support 20/40/80/160MHz at 6GHz
| Modulation Techniques
| OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
| Temperature Range
| Operating: -20°C to 70°C, Storage: -40°C to 90°C
| Humidity
| Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
| Certification
| TBD
| Power Consumption
| TBD
| Reference Design
| PN02.7
| Dimensions (WxHxD)
| 57mm x 63mm x 6mm
