In some traditional management mode, the wired network in the factory has no way to meet the needs of mobile office and mobile scanning code, especially in some special environment workshop, warehouse, can not walk the line at will is a hard injury, so it is necessary to carry out wireless signal coverage on the factory regional network. Industrial-grade wireless AP is the equipment for wireless LAN coverage in harsh environments such as factories, workshops and mines in special environments. At the same time, it helps some factories to create a very stable and secure network environment, making the network more convenient for business services.
Wallys Communications (Suzhou) Co., LTD is one of these industrial-grade wireless AP manufacturers. Our equipment is widely used in severe environments such as thermal power stations, mining areas, and freezers, with stable quality. Because for some industrial parks, it is very important to ensure that some users can access the Internet and exchange with the public information network platform in the park. In such a case, it is necessary to cover some wireless network signals inside the factory. In addition, it is worth noting that in addition to some indoor public areas or areas in the factory, it is also necessary to cover all outdoor activity areas with wireless signals. In addition, if it is a wireless network of mesh devices to interact with each other, it is also very recommended, through this way to achieve the conversion between wireless network and wired network. There are some employees who need Internet access in the factory, or just to be able to meet their work needs, but also need to meet their living needs. Therefore, it is very necessary to realize the secure access of wireless terminals. At the same time, unified monitoring and management are also needed for these wireless network devices, so as to avoid too many problems in the process of use.
At present, the wireless network in many places is actually based on the platform of a wireless network system, through the access and deployment of some wireless network terminals, some characteristics of network efficiency optimization. It is also a kind of network connection that provides self-organization and self-repair. Only with such openness and advancement of wireless network can the wireless network in the factory be more stable and convenient. In addition, it is worth noting that for wireless networks, there are certain requirements for the use of industrial wireless AP. Description DR-AP40X9-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);1 x Enclosure. Dipole antenna ■ 2 x 2.4G&5G Antenna■ 5dBi 2.4GHz/5Ghz■ SMA Plug interface ■ Plastic rod of black ■ RoHS compliance Enclosure■ Dimension: 132x 119 x 34 mm■ Aluminum alloy material■ Support WallysDR40X9 There are other similar products R-AP6018-A DR-AP6018-S-AWallys Communications (SuZhou) Co.,Ltd utilizes its own professional knowledge and the top research and development team unceasingly breaks through, we have the hardware, the software, the RF, the antenna, the enclosure and so on design ability.To provide customers with customized services, products from Design - Test -Certification - Production of one-stop convenient services. Wallys independent research and development and production of standard and proprietary protocol of wireless bridge, wireless AP, and frequency conversion equipment related products, comprehensive application in security, transportation, ports, oil fields, mines, logistics, electric power, tourism, forest fire prevention, safe city and other industries, won the general customers the consistent high praise, has the good public praise and reputation in the industry.
Wallys Communications (Suzhou ) Co., LTD
Email:sales1@wallystech.com
