Item | Description |
Max. number of simultaneous device connections | 100 |
client connections 1 | No limit (operation guaranteed up to 32 clients) |
Max. number of simultaneous device connections per project | 100 |
Max. number of simultaneous operation projects | 30
For a 5000 tag or 10000 tag model: 3 5 |
Max. number of device
registrations | 1000 |
Max. number of project registrations | 10000 |
Max. number of user registrations | 100 |
Max. number of clients that can run simultaneously on the same PC | Multiple clients possible (See “Starting Multiple Screens” described later.) |
Monitor interval (when set to PC time) | 100 ms, 200 ms, 500 ms, 1 s, 2 s,
5 s, 10 s, 20 s, 30 s, 1 min, 2 min, 5
min, 10 min, 30 min, 1 hour |
Monitor interval
(when set to device time) 6 | The acquisition interval of each
device. 2 |
Record interval (when set to PC time) | 100 ms, 200 ms, 500 ms, 1 s, 2 s,
2 min, 5 min, 10 min, 30 min, 1 hour (limited to an integer
multiple of the monitor interval) |
Record interval
(when set to device time) | Same as the monitor interval of GA10. |
Maximum number of recording tags (channels) per project | 10000 4 5
Models with the math function: 12000 (including the maximum math tags of 2000) |
Number of display groups | 50
For a 5000 tag, 10000 tag, or GateSushi-added model: 200 |
Number of channels (tags) per
display group | 50 |
Language | English, Japanese, Chinese, French, German, Russian, Korean |
