Internally generated gate voltage supply. Not to be used as a supply or connected to any component other than a 1 µF X7R ceramic decoupling capacitor and the MODE resistor divider.
SDA
4
I
I2C data.
SCL
5
I
I2C clock.
IN+
6
I
Positive differential input.
IN-
7
I
Negative differential input.
STDBY
8
I
Standby pin.
BSTN
10
P
Boot strap for negative output, connect to 220 nF X5R, or better ceramic cap to OUT-.
OUT-
11
O
Negative output.
OUT+
12
O
Positive output.
BSTP
13
P
Boot strap for positive output, connect to 220 nF X5R, or better ceramic cap to OUT+.
INTZ
14
O
General fault reporting. Open drain. INTZ = High, normal operation INTZ = Low, fault condition
VDD
15
P
Power supply.
Thermal Pad
G
Connect to GND for best system performance. If not connected to GND, leave floating.
6 规格
6.1 绝对最大额定值
在自由空气工作温度范围内(除非另有说明)(1)
MIN
MAX
UNIT
Supply voltage
VDD DC supply voltage range
–0.3
30
V
VDD pulsed supply voltage range. t < 400 ms exposure
