QSDK/industrial wifi6 routerboard/ IPQ8072A-
IPQ8074A/4T4R
OPENWRT 10GE port 10G-SFP 2.4G and 5G
As SoC is only one of the components of router, wireless network chip, switch chip, FEM, antenna gain, design and work materials will affect the overall performance.
The ipq8074/8072 are both quad-core A53 2.2GHz, 14nm manufacturing process, with dual-core NPU (network processor).
IPQ8074 is
Qualcomm's first WiFi6 networking solution designed to meet the growing demands of an increasingly crowded and dense Wi-Fi environment. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks, and supports several unique features to ensure the best Wi-Fi performance for all types of applications. Q8074A compared to IPQ8074, IPQ8074A adds MU-
MIMO Uplink,
OFDMA -- UL, MU-RTS (Multi-User Request To Send), Preamble Puncture, Spatial Reuse (OBSS PD) and other functions. Maximize payload data rate by increasing efficiency, reduce contention between STAs and improve channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also better.
DR8074A(HK01)
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB
NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz■ Supports Dynamic Frequency Selection (DFS)
Symbol |
Parameter |
CPU |
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU |
CPU Frequency |
Derived from Qualcomm Atheros AP.HK01 |
System Memory |
1GB (2x 512MB) DDR3L 32-bit interface |
Frequency Range |
2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz |
Modulation Techniques |
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM |
NGFF Slot for 5G Module |
M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface |
Optional Onboard Modules |
Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header |
Flash |
NOR Flash: 32MB NAND Flash: 256MB
eMMC: 8GB |
Wireless |
On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
12x U.FL connectors |
Reset Buttons |
2x Hardware reset button, 1x WPS reset button |
DC Jack Input |
1x DC Jack Connector: 12V, 5A |
Interface |
5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
2x USB 3.0 Port
1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
1x micro SD Card Socket
1x M.2 Slot |
LED |
13x LED indicators, 2 additional LED on Ethernet port |
Power Consumption |
TBD |
DR8072 V01
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074
production
Symbol |
Parameter |
CPU |
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU |
CPU Frequency |
Derived from Qualcomm Atheros AP.HK09 |
System Memory |
1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional) |
Frequency Range |
2.412~2.472GHz, 5.150~5.825GHz |
M.2 Slot |
1x M.2 Slot with PCIe 3.0 |
Environmental Temperature |
Operating: -20ºC to 70ºC, Storage: -40ºC to 90ºC |
Flash |
NOR Flash: 8 MB NAND Flash: 256MB(1GB optional) |
Wireless |
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors |
Reset Buttons |
1x S/W Reset Button |
DC Jack Input |
1x DC Jack Connector: 12V |
Interface |
4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port
1x 10Gbps SFP2x USB 3.0 Port
1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector |
LED |
2x RGB LED Indicators |
Power Consumption |
TBD |
Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase. Therefore, it is essential to have a rOBUst, secure and high performing WiFi solution that is future-proofed, mobile, and scalable. Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook
