已绑定手机 已绑定手机
RX-NR
| MT6190 | | SDR735 (NR) | No. | Parameter | Test conditions | Min. | Typ. | Max. | Unit |
| Parameter | Test conditions | Min. | Typ. | Max. | Unit | 1 | Single-ended input impedance |
| | 50 |
| Ohm |
| 2 | Single-ended input return loss |
| | -10 |
| dB |
| Input VSWR (in-band) |
| | 2:1 |
| | 3 |
| LO-to-RF leakage (in-band) | All gain modes; at iLNA input |
| | -47 | dBm | 4 |
| Residual sideband | Due to amplitude and phase imbalance (uncalibrated) |
| | -25 | dBc | 5 | Input frequency |
| 703.00 |
| 500 | MHz |
| 6 | Voltage gain | Max: LNA HG; TIA HG; filter gain = 18 dB 42.1 dB
Min: LNA MG; TIA HG; filter gain = 0 dB |
| 42.1
18.1 |
| dB |
| 7 | LNA gain step | LNA high ßà mid gain; source VSWR < 1.2 5 6 7 dB
LNA mid ßà low gain; source VSWR < 1.2 | 5
5 | 6
6 | 7
7 | dB |
| 8 | TIA gain step | Fix TIA at HG |
| dB |
| 9 | LPF gain step | Range from 0 dB to 18 dB, 3 dB per step |
| dB |
| 10 | Channel edge signal
drooping | BW = 1.4 MHz mode
BW = 3 MHz mode
BW = 5 MHz mode
BW = 10 MHz mode
BW = 15 MHz mode
BW = 20 MHz mode
BW = 30 MHz mode
BW = 40 MHz mode
BW = 50 MHz mode
BW = 60 MHz mode
BW = 80 MHz mode
BW = 100 MHz mode
BW = 120 MHz mode
BW = 140 MHz mode
BW = 160 MHz mode
BW = 180 MHz mode
BW = 200 MHz mode |
| 0.11
0.39
1.77
0.71
1.85
1.85
4.10
4.38
3.64
3.70
3.91
3.91
3.91
3.91
3.91
3.91
3.91 |
| dB |
| 11 | Test condition 1 (LNA=HG, TIA=HG, LPF=18dB) [Sen] |
| Gain mode G0 | 12 | Noise Figure | Frequency < 960 MHz
1427 MHz < frequency < 2690 MHz
3300 MHz < frequency < 5000 MHz |
| 8
9
9 | 10
11
11 | dB |
| Voltage conversion gain |
| 36.50 | 39.5 | 42.5 | dBV/V | 13 | IIP2 | At TX offset, frequency < 2690 MHz
(after calibration) | 73.00 |
| | dBm |
| Noise Figure | All except n77,n78,n79
All NCCA except n77,n78,n79
n77,n78,n79
n77,n78,n79 NCCA |
| | 13.5
15.0
11.0
12.0 | dB | 14 | Voltage gain | LNA = HG, TIA=HG, LPF=18dB |
| 42.1 |
| dB |
| Input IP2
(Self Tx) | S=-71dBm
Tx1=Tx2=-11dBm
After factory calibration |
| 73 |
| dBm | 15 | Test condition 2 (LNA=MG, TIA=HG, LPF=6dB) [ACS1] |
| 16 | Noise Figure |
| | 21 |
| dB |
| Input IP3
(ACS) | All except n48, n77, n78, n79
S=-71dBm
J1=J2=-45dBm
n48, n77, n78, n79
S=-76dBm
J1=J2=-41dBm | -14,00
-11.00 |
| | dBm | 17 | IIP3 | ±4.5 MHz and ±5.5 MHz offset
LNA = MG, TIA=HG, LPF=3dB
-32 dBm per tone |
| 5 |
| dBm |
| Input IP3
(Triple Beat) | S=-71 dBm
J= -39dBm, TX1=TX2=-15dBm | 0.00 |
| | dBm | 18 | Voltage gain | LNA = MG, TIA=HG, LPF=3dB |
| 24.1 |
| dB |
| | | | | | | 19 | Test condition 3 (LNA=MG, TIA=HG, LPF=0dB) [ACS2] |
| Gain mode G1 | 20 | Noise Figure |
| | 26 |
| dB |
| Voltage conversion gain | Allexcept n48, n77, n78, n79
n48, n77, n78, n79 | 31.5
28.5 | 34.5
31.5 | 37.5
34.5 | dBV/V | 21 | IIP3 | ±4.5 MHz and ±5.5 MHz offset
-25 dBm per tone |
| 5 |
| dBm |
| Noise Figure |
| 16 | dB | 22 | Voltage gain | LNA = MG, TIA=HG, LPF=3dB |
| 18.1 |
| dB |
| Input IP3
S=-65dBm
J1=J2=-38dBm
n48, n77, n78, n79
S=-64dBm
J1=J2=-32dBm | -8,00
-5.00 |
| | dBm | 23 | Test condition 4 (LNA=MG, TIA=HG, LPF=0dB) [maximum input] |
| Gain mode G2 | 24 | Noise Figure |
| | 26 |
| dB |
| 28.50 | 31.5 | 34.5 | dBV/V | 25 | Voltage gain | LNA = MG, TIA=HG, LPF=0dB |
| 18.1 |
| dB |
| Noise Figure | Allexcept n48, n77, n78, n79
| | 17.0
15.0 | dB | 26 |
| Input IP3
S=-65dBm
J1=J2=-32dBm
n48, n77, n78, n79
S=-65dBm
-5.00 |
| | dBm | 27 |
| Gain mode G3 | 28 |
| 25.50 | 28.5 | 31.5 | dBV/V | 29 |
| | 20.0
17.5 | dB | 30 |
| Input IP3
S=-59dBm
J1=J2=-32dBm
n48, n77, n78, n79
S=-62dBm
J1=J2=-29dBm | -5,00
-2.00 |
| | dBm | 31 |
| Gain mode G4 | 32 |
| 22.50 | 25.5 | 28.5 | dBV/V | 33 |
| | 21.5
22.0 | dB | 34 |
| Input IP3
S=-53dBm
J1=J2=-29dBm
n48, n77, n78, n79
S=-59dBm
J1=J2=-26dBm | -2,00
1.00 |
| | dBm |
MT6186M_MT6190M_SDR735_RF性能对比
MT6186M_MT6190M_SDR735_RF性能对比.xlsx
(52.2 KB, 下载次数: 3, 售价: 5 RD币)
