Address | Name | Width | Register Function |
10342000 | slb_si | 32 | SLB SI Register |
10342004 | slc_cmd_con | 32 | SLC Control Register |
10342008 | slc_arb_con | 32 | SLC Arbitration Setting |
1034200C | slc_dss_ctl | 32 | SLC DSS Control |
10342010 | slc_way_dis_ctl | 32 | SLC Way Disabling Control |
10342014 | sram_int_clr | 32 | SRAM Parity Error Interrupt |
10342018 | slc_bist_ctrl | 32 | SLC BIST Control |
10342020 | slc_way_rsv_ctl0 | 32 | SLC Way Reservation Control 0 |
10342024 | slc_way_rsv_ctl1 | 32 | SLC Way Reservation Control 1 |
10342028 | slc_way_rsv_ctl2 | 32 | SLC Way Reservation Control 2 |
1034202C | slc_way_rsv_ctl3 | 32 | SLC Way Reservation Control 3 |
10342030 | slc_way_rsv_ctl4 | 32 | SLC Way Reservation Control 4 |
10342034 | slc_way_rsv_ctl5 | 32 | SLC Way Reservation Control 5 |
10342038 | slc_way_rsv_ctl6 | 32 | SLC Way Reservation Control 6 |
1034203C | slc_way_rsv_ctl7 | 32 | SLC Way Reservation Control 7 |
10342040 | slc_way_rsv_ctl8 | 32 | SLC Way Reservation Control 8 |
10342044 | slc_way_rsv_ctl9 | 32 | SLC Way Reservation Control 9 |
10342048 | slc_way_rsv_ctl10 | 32 | SLC Way Reservation Control 10 |
1034204C | slc_way_rsv_ctl11 | 32 | SLC Way Reservation Control 11 |
10342050 | slc_way_rsv_ctl12 | 32 | SLC Way Reservation Control 12 |
10342054 | slc_way_rsv_ctl13 | 32 | SLC Way Reservation Control 13 |
10342058 | slc_way_rsv_ctl14 | 32 | SLC Way Reservation Control 14 |
1034205C | slc_way_rsv_ctl15 | 32 | SLC Way Reservation Control 15 |
10342080 | slc_dswq_ctrl0 | 32 | SLC Data Switch Queue Control 0 |
10342084 | Tag_debug_ctrl | 32 | Tag Debug Control |
10342088 | slc_last_slc_ctrl | 32 | SLC Last SLC Control |
10342090 | slc_spare0_low | 32 | SLC ECO0 |
10342094 | slc_spare1_low | 32 | SLC ECO1 |
10342098 | slc_spare2_low | 32 | SLC ECO2 |
1034209C | slc_spare3_high | 32 | SLC ECO3 |
10342100 | slc_pmu_cnt0_filter0 | 32 | SLC_pmu_cnt0_filter0 |
10342104 | slc_pmu_cnt0_filter1 | 32 | SLC_pmu_cnt0_filter1 |
10342108 | slc_pmu_cnt0_bw_lat_sel | 32 | slc_pmu_cnt0_bandwidth_latency_select |
10342110 | slc_pmu_cnt1_filter0 | 32 | SLC_pmu_cnt1_filter0 |
10342114 | slc_pmu_cnt1_filter1 | 32 | SLC_pmu_cnt1_filter1 |
10342118 | slc_pmu_cnt1_bw_lat_sel | 32 | slc_pmu_cnt1_bandwidth_latency_select |
10342120 | slc_pmu_cnt2_filter0 | 32 | SLC_pmu_cnt2_filter0 |
10342124 | slc_pmu_cnt2_filter1 | 32 | SLC_pmu_cnt2_filter1 |
10342128 | slc_pmu_cnt2_bw_lat_sel | 32 | slc_pmu_cnt2_bandwidth_latency_select |
10342130 | slc_pmu_cnt3_filter0 | 32 | SLC_pmu_cnt3_filter0 |
10342134 | slc_pmu_cnt3_filter1 | 32 | SLC_pmu_cnt3_filter1 |
10342138 | slc_pmu_cnt3_bw_lat_sel | 32 | slc_pmu_cnt3_bandwidth_latency_select |
10342140 | slc_pmu_cnt4_filter0 | 32 | SLC_pmu_cnt4_filter0 |
10342144 | slc_pmu_cnt4_filter1 | 32 | SLC_pmu_cnt4_filter1 |
10342148 | slc_pmu_cnt4_bw_lat_sel | 32 | slc_pmu_cnt4_bandwidth_latency_select |
10342150 | slc_pmu_cnt5_filter0 | 32 | SLC_pmu_cnt5_filter0 |
10342154 | slc_pmu_cnt5_filter1 | 32 | SLC_pmu_cnt5_filter1 |
10342158 | slc_pmu_cnt5_bw_lat_sel | 32 | slc_pmu_cnt5_bandwidth_latency_select |
10342160 | slc_pmu_cnt6_filter0 | 32 | SLC_pmu_cnt6_filter0 |
10342164 | slc_pmu_cnt6_filter1 | 32 | SLC_pmu_cnt6_filter1 |
10342168 | slc_pmu_cnt6_bw_lat_sel | 32 | slc_pmu_cnt6_bandwidth_latency_select |
10342170 | slc_pmu_cnt7_filter0 | 32 | SLC_pmu_cnt7_filter0 |
10342174 | slc_pmu_cnt7_filter1 | 32 | SLC_pmu_cnt7_filter1 |
10342178 | slc_pmu_cnt7_bw_lat_sel | 32 | slc_pmu_cnt7_bandwidth_latency_select |
10342180 | slc_pmu_cnt8_filter0 | 32 | SLC_pmu_cnt8_filter0 |
10342184 | slc_pmu_cnt8_filter1 | 32 | SLC_pmu_cnt8_filter1 |
10342188 | slc_pmu_cnt8_bw_lat_sel | 32 | slc_pmu_cnt8_bandwidth_latency_select |
10342190 | slc_pmu_cnt9_filter0 | 32 | SLC_pmu_cnt9_filter0 |
10342194 | slc_pmu_cnt9_filter1 | 32 | SLC_pmu_cnt9_filter1 |
10342198 | slc_pmu_cnt9_bw_lat_sel | 32 | slc_pmu_cnt9_bandwidth_latency_select |
103421A0 | slc_pmu_cnt10_filter0 | 32 | SLC_pmu_cnt10_filter0 |
103421A4 | slc_pmu_cnt10_filter1 | 32 | SLC_pmu_cnt10_filter1 |
103421A8 | slc_pmu_cnt10_bw_lat_sel | 32 | slc_pmu_cnt10_bandwidth_latency_select |
103421B0 | slc_pmu_cnt11_filter0 | 32 | SLC_pmu_cnt11_filter0 |
103421B4 | slc_pmu_cnt11_filter1 | 32 | SLC_pmu_cnt11_filter1 |
103421B8 | slc_pmu_cnt11_bw_lat_sel | 32 | slc_pmu_cnt11_bandwidth_latency_select |
103421C0 | slc_pmu_cnt12_filter0 | 32 | SLC_pmu_cnt12_filter0 |
103421C4 | slc_pmu_cnt12_filter1 | 32 | SLC_pmu_cnt12_filter1 |
103421C8 | slc_pmu_cnt12_bw_lat_sel | 32 | slc_pmu_cnt12_bandwidth_latency_select |
103421D0 | slc_pmu_cnt13_filter0 | 32 | SLC_pmu_cnt13_filter0 |
103421D4 | slc_pmu_cnt13_filter1 | 32 | SLC_pmu_cnt13_filter1 |
103421D8 | slc_pmu_cnt13_bw_lat_sel | 32 | slc_pmu_cnt13_bandwidth_latency_select |
103421E0 | slc_pmu_cnt14_filter0 | 32 | SLC_pmu_cnt14_filter0 |
103421E4 | slc_pmu_cnt14_filter1 | 32 | SLC_pmu_cnt14_filter1 |
103421E8 | slc_pmu_cnt14_bw_lat_sel | 32 | slc_pmu_cnt14_bandwidth_latency_select |
103421F0 | slc_pmu_cnt15_filter0 | 32 | SLC_pmu_cnt15_filter0 |
103421F4 | slc_pmu_cnt15_filter1 | 32 | SLC_pmu_cnt15_filter1 |
103421F8 | slc_pmu_cnt15_bw_lat_sel | 32 | slc_pmu_cnt15_bandwidth_latency_select |
10342200 | slc_pmu_cnt16_filter0 | 32 | SLC_pmu_cnt16_filter0 |
10342204 | slc_pmu_cnt16_filter1 | 32 | SLC_pmu_cnt16_filter1 |
10342208 | slc_pmu_cnt16_bw_lat_sel | 32 | slc_pmu_cnt16_bandwidth_latency_select |
10342210 | slc_pmu_cnt17_filter0 | 32 | SLC_pmu_cnt17_filter0 |
10342214 | slc_pmu_cnt17_filter1 | 32 | SLC_pmu_cnt17_filter1 |
10342218 | slc_pmu_cnt17_bw_lat_sel | 32 | slc_pmu_cnt17_bandwidth_latency_select |
10342220 | slc_pmu_cnt18_filter0 | 32 | SLC_pmu_cnt18_filter0 |
10342224 | slc_pmu_cnt18_filter1 | 32 | SLC_pmu_cnt18_filter1 |
10342228 | slc_pmu_cnt18_bw_lat_sel | 32 | slc_pmu_cnt18_bandwidth_latency_select |
10342230 | slc_pmu_cnt19_filter0 | 32 | SLC_pmu_cnt19_filter0 |
10342234 | slc_pmu_cnt19_filter1 | 32 | SLC_pmu_cnt19_filter1 |
10342238 | slc_pmu_cnt19_bw_lat_sel | 32 | slc_pmu_cnt19_bandwidth_latency_select |
10342240 | slc_pmu_cnt20_filter0 | 32 | SLC_pmu_cnt20_filter0 |
10342244 | slc_pmu_cnt20_filter1 | 32 | SLC_pmu_cnt20_filter1 |
10342248 | slc_pmu_cnt20_bw_lat_sel | 32 | slc_pmu_cnt20_bandwidth_latency_select |
10342250 | slc_pmu_cnt21_filter0 | 32 | SLC_pmu_cnt21_filter0 |
10342254 | slc_pmu_cnt21_filter1 | 32 | SLC_pmu_cnt21_filter1 |
10342258 | slc_pmu_cnt21_bw_lat_sel | 32 | slc_pmu_cnt21_bandwidth_latency_select |
10342260 | slc_pmu_cnt22_filter0 | 32 | SLC_pmu_cnt22_filter0 |
10342264 | slc_pmu_cnt22_filter1 | 32 | SLC_pmu_cnt22_filter1 |
10342268 | slc_pmu_cnt22_bw_lat_sel | 32 | slc_pmu_cnt22_bandwidth_latency_select |
10342270 | slc_pmu_cnt23_filter0 | 32 | SLC_pmu_cnt23_filter0 |
10342274 | slc_pmu_cnt23_filter1 | 32 | SLC_pmu_cnt23_filter1 |
10342278 | slc_pmu_cnt23_bw_lat_sel | 32 | slc_pmu_cnt23_bandwidth_latency_select |
10342280 | slc_pmu_cnt24_filter0 | 32 | SLC_pmu_cnt24_filter0 |
10342284 | slc_pmu_cnt24_filter1 | 32 | SLC_pmu_cnt24_filter1 |
10342288 | slc_pmu_cnt24_bw_lat_sel | 32 | slc_pmu_cnt24_bandwidth_latency_select |
10342290 | slc_pmu_cnt25_filter0 | 32 | SLC_pmu_cnt25_filter0 |
10342294 | slc_pmu_cnt25_filter1 | 32 | SLC_pmu_cnt25_filter1 |
10342298 | slc_pmu_cnt25_bw_lat_sel | 32 | slc_pmu_cnt25_bandwidth_latency_select |
103422A0 | slc_pmu_cnt26_filter0 | 32 | SLC_pmu_cnt26_filter0 |
103422A4 | slc_pmu_cnt26_filter1 | 32 | SLC_pmu_cnt26_filter1 |
103422A8 | slc_pmu_cnt26_bw_lat_sel | 32 | slc_pmu_cnt26_bandwidth_latency_select |
103422B0 | slc_pmu_cnt27_filter0 | 32 | SLC_pmu_cnt27_filter0 |
103422B4 | slc_pmu_cnt27_filter1 | 32 | SLC_pmu_cnt27_filter1 |
103422B8 | slc_pmu_cnt27_bw_lat_sel | 32 | slc_pmu_cnt27_bandwidth_latency_select |
103422C0 | slc_pmu_cnt28_filter0 | 32 | SLC_pmu_cnt28_filter0 |
103422C4 | slc_pmu_cnt28_filter1 | 32 | SLC_pmu_cnt28_filter1 |
103422C8 | slc_pmu_cnt28_bw_lat_sel | 32 | slc_pmu_cnt28_bandwidth_latency_select |
103422D0 | slc_pmu_cnt29_filter0 | 32 | SLC_pmu_cnt29_filter0 |
103422D4 | slc_pmu_cnt29_filter1 | 32 | SLC_pmu_cnt29_filter1 |
103422D8 | slc_pmu_cnt29_bw_lat_sel | 32 | slc_pmu_cnt29_bandwidth_latency_select |
103422E0 | slc_pmu_cnt30_filter0 | 32 | SLC_pmu_cnt30_filter0 |
103422E4 | slc_pmu_cnt30_filter1 | 32 | SLC_pmu_cnt30_filter1 |
103422E8 | slc_pmu_cnt30_bw_lat_sel | 32 | slc_pmu_cnt30_bandwidth_latency_select |
103422F0 | slc_pmu_cnt31_filter0 | 32 | SLC_pmu_cnt31_filter0 |
103422F4 | slc_pmu_cnt31_filter1 | 32 | SLC_pmu_cnt31_filter1 |
103422F8 | slc_pmu_cnt31_bw_lat_sel | 32 | slc_pmu_cnt31_bandwidth_latency_select |
10342300 | slc_pmu_ctrl_set0_set7 | 32 | slc_pmu_control_set0_to_set7 |
10342304 | slc_pmu_ctrl_set8_set15 | 32 | slc_pmu_control_set8_to_set15 |
10342308 | slc_pmu_ctrl_set16_set23 | 32 | slc_pmu_control_set16_to_set23 |
1034230C | slc_pmu_ctrl_set24_set31 | 32 | slc_pmu_control_set24_to_set31 |
