MJ15003 和 MJ15004 是专为高功率音频、磁头定位器和其他线性应用而设计的功率晶体管。
• 高安全作业区
• 对于低失真互补设计
• 高直流电流增益
• 这些器件不含铅且符合 RoHS 标准*
最大额定值
Rating | Symbol | Value | Unit |
Collector−Emitter Voltage | VCEO | 140 | Vdc |
Collector−Base Voltage | VCBO | 140 | Vdc |
Emitter−Base Voltage | VEBO | 5 | Vdc |
Collector Current − Continuous | IC | 20 | Adc |
Base Current − Continuous | IB | 5 | Adc |
Emitter Current − Continuous | IE | 25 | Adc |
Total Power Dissipation @ TC = 25℃ Derate above 25℃ | PD | 250
1.43 | W
W/℃ |
Operating and Storage Junction Temperature Range | TJ, Tstg | –65 to +200 | ℃ |
电气特性(除非另有说明,否则 TC = 25°C)
Characteristic | Symbol | Min | Max | Unit |
OFF CHARACTERISTICS |
Collector Emitter Sustaining Voltage (Note 1) (IC = 200 mAdc, IB = 0) | VCEO(sus) | 140 | − | Vdc |
Collector Cutoff Current
(VCE = 140 Vdc, VBE(off) = 1.5 Vdc)
(VCE = 140 Vdc, VBE(off) = 1.5 Vdc, TC = 150C) | ICEX | −
− | 100
2 | Adc mAdc |
Collector Cutoff Current (VCE = 140 Vdc, IB = 0) | ICEO | − | 250 | Adc |
Emitter Cutoff Current (VEB = 5 Vdc, IC = 0) | IEBO | − | 100 | Adc |
SECOND BREAKDOWN |
Second Breakdown Collector Current with Base Forward Biased (VCE = 50 Vdc, t = 1 s (non repetitive))
(VCE = 100 Vdc, t = 1 s (non repetitive)) | IS/b | 5.0
1.0 | −
− | Adc |
ON CHARACTERISTICS |
DC Current Gain
(IC = 5 Adc, VCE = 2 Vdc) | hFE | 25 | 150 | − |
Collector Emitter Saturation Voltage (IC = 5 Adc, IB = 0.5 Adc) | VCE(sat) | − | 1.0 | Vdc |
Base Emitter On Voltage
(IC = 5 Adc, VCE = 2 Vdc) | VBE(on) | − | 2.0 | Vdc |
DYNAMIC CHARACTERISTICS |
Current Gain — Bandwidth product
(IC = 0.5 Adc, VCE = 10 Vdc, ftest = 0.5 MHz) | fT | 2.0 | − | MHz |
Output Capacitance
(VCB = 10 Vdc, IE = 0, ftest = 1 MHz) | cob | − | 1000 | pF |
