Address | Name | Width | Register Function |
11240000 | MSDC_CFG | 32 | MSDC Configuration Register |
11240004 | MSDC_IOCON | 32 | MSDC I/O Configuration Register |
11240008 | MSDC_PS | 32 | MSDC Pin Status Register |
1124000C | MSDC_INT | 32 | MSDC Interrupt Register |
11240010 | MSDC_INTEN | 32 | MSDC Interrupt Enable Register |
11240014 | MSDC_FIFOCS | 32 | MSDC FIFO Control and Status Register |
11240018 | MSDC_TXDATA | 32 | MSDC Tx Data Port Register |
1124001C | MSDC_RXDATA | 32 | MSDC Rx Data Port Register |
11240030 | SDC_CFG | 32 | SD Configuration Register |
11240034 | SDC_CMD | 32 | SD Command Register |
11240038 | SDC_ARG | 32 | SD Argument Register |
1124003C | SDC_STS | 32 | SD Status Register |
11240040 | SDC_RESP0 | 32 | SD Response Register 0 |
11240044 | SDC_RESP1 | 32 | SD Response Register 1 |
11240048 | SDC_RESP2 | 32 | SD Response Register 2 |
1124004C | SDC_RESP3 | 32 | SD Response Register 3 |
11240050 | SDC_BLK_NUM | 32 | SD Block Number Register |
11240054 | SDC_VOL_CHG | 32 | SD Voltage Change Wait Time Register |
11240058 | SDC_CSTS | 32 | SD Card Status Register |
1124005C | SDC_CSTS_EN | 32 | SD Card Status Enable Register |
11240060 | SDC_DATCRC_STS | 32 | SD Card Data CRC Status Register |
11240064 | SDC_ADV_CFG0 | 32 | SDC Advance Configuration 0 |
11240070 | EMMC_CFG0 | 32 | eMMC Configuration Register 0 |
11240074 | EMMC_CFG1 | 32 | eMMC Configuration Register 1 |
11240078 | EMMC_STS | 32 | eMMC Status Register |
1124007C | EMMC_IOCON | 32 | eMMC I/O Control Register |
11240080 | SD_ACMD_RESP | 32 | SD ACMD Response Register |
11240084 | SD_ACMD19_TRG | 32 | SD ACMD19 Target Register |
11240088 | SD_ACMD19_STS | 32 | SD ACMD19 Status Register |
1124008C | DMA_SA_HIGH4BIT | 32 | DMA Start Address Register of High 4 bits |
11240090 | DMA_SA | 32 | DMA Start Address Register |
11240094 | DMA_CA | 32 | DMA Current Address Register |
11240098 | DMA_CTRL | 32 | DMA Control Register |
1124009C | DMA_CFG | 32 | DMA Configuration Register |
112400A0 | SW_DBG_SEL | 32 | MSDC Software Debug Selection Register |
112400A4 | SW_DBG_OUT | 32 | MSDC Software Debug Output Register |
112400A8 | DMA_LENGTH | 32 | DMA Length Register |
112400B0 | PATCH_BIT0 | 32 | MSDC Patch Bit Register 0 |
112400B4 | PATCH_BIT1 | 32 | MSDC Patch Bit Register 1 |
112400B8 | PATCH_BIT2 | 32 | MSDC Patch Bit Register 2 |
112400F0 | PAD_TUNE0 | 32 | MSDC Pad Tuning Register 0 |
11240110 | HW_DBG_SEL | 32 | MSDC Hardware Debug Selection Register |
11240114 | MAIN_VER | 32 | MSDC Main Version Register |
11240118 | ECO_VER | 32 | MSDC ECO Version Register |
11240204 | SW_CMDQ_CFG0 | 32 | SW CMDQ Configuration Register 0 |
11240228 | SDC_FIFO_CFG | 32 | 1KB FIFO configure |
