问题描述(Issue Description)
[CTS\GTS\VTS…Test Step] :
− cd Android-sts/tools
− ./sts-tradefed
− run sts-engbuild
[CTS/GTS/VTS Version] : STS 8.1_201911_arm
[GMS/GSI Version]: 8.1_201911.go
[Security Patch]: 2019-11-05
[Testing Result]:
CtsSecurityBulletinHostTestCases --android.security.cts.Poc18_06#testPocCVE_2018_9349 fail
fail: junit.Framework.AssertionFailedError: The device ran out of memory.
at junit.framework.Assert.fail(Assert.java:57)
at junit.framework.TestCase.fail(TestCase.java:227)
at android.security.cts.SecurityTestCase.tearDown(SecurityTestCase.java:77)
问题分析(Analysis)
10-22 10:27:43 D/JarHostTest: HostTestlistener.testRunStarted(android.security.cts.Poc18_06, 1)
10-22 10:27:54.468 860 2868 I ActivityManager: START u0 {act=android.intent.action.MAIN
cat=[android.intent.category.Launcher] flg=0x10000000 cmp=com.android.cts.oomcatcher/.OomCatcher} from uid 2000, pid 3188
10-22 10:28:49.710 3190 3190 I OomCatcher: Memory trim level: 15
10-22 10:28:49.710 3190 3190 I OomCatcher: Low memory
经过反编译测试APK,我们发现这个问题的根本原因是OomCatcher捕捉到了 "低内存 "日志。
解决方案(Solution)
[Solution]:
Google marked issue 143128220 as fixed.
"Marked as fixed.
这对弃权来说是合适的。我们知道这个问题,它在即将到来的STS版本中得到了修复。"
[Patch Link]:
NA
结论(Conclusion)
结果
谷歌反馈
信息
谷歌确认此弃权
YES
rishigulati@google.com
<rishigulati@google.com
> #4Oct 22, 2019
07:30PM
Marked as fixed.
07:30PM
"This is appropriate for a
waiver. We know about
this issue and it's fixed in
the upcoming version of
STS."
