•高隔离,63 dB typ。 在1GHz
•高IIP3, +44DBM典型。 在1GHz
•低插入损失,0.5 dB typ.at 1GHz
•快速上升 /秋季时间,5.6 ns / 6 ns typ。
典型应用
•防御
•通信基础架构
•测试和测量
主要特征
Feature
Advantages
Wideband, DC to 6 GHz
One model can be used in many applications, saving component count. Also ideal for wideband applications such as military and instrumentation.
Absorptive switch
In the OFF condition, RF output ports which are not switched ON are terminated into 50 . This enables proper impedance termination of the circuitry following the RF output ports, preventing any unintended action such as oscillation.
High Isolation:
• 63 dB at 1 GHz
• 29 dB at 6 GHz
High isolation significantly reduces leakage of power into OFF ports.
HHigh linearity:
Pin at P1dB 26.2dBm typ. at 1GHz, Input IP3, 44dBm typ. at 1GHz
High linearity minimizes unwanted intermodulation products which are difficult or impossible to filter in multi-carrier environments such as CATV, or in the presence of strong interfering signal from adjacent circuitry or received by antenna.
Unpackaged die
Enables user to integrate it directly into hybrids.
