Address | Name | Width | Register Function |
112B0000 | UFS_CAP | 32 | Host Controller Capabilities |
112B0008 | UFS_VER | 32 | UFS Version |
112B0010 | UFS_HCDDID | 32 | Host Controller Identification Descriptor |
112B0014 | UFS_HCPMID | 32 | Host Controller Identification Descriptor |
112B0018 | UFS_AHIT | 32 | Auto-Hibernate Idle Timer |
112B0020 | UFS_IS | 32 | Interrupt Status |
112B0024 | UFS_IE | 32 | Interrupt Enable |
112B0030 | UFS_HCS | 32 | Host Controller Status |
112B0034 | UFS_HCE | 32 | Host Controller Enable |
112B0038 | UFS_UECPA | 32 | Host Controller UIC Error Code PHY Adapter Layer |
112B003C | UFS_UECDL | 32 | Host UIC Error Code Data Link Layer |
112B0040 | UFS_UECN | 32 | Host UIC Error Code Network Layer |
112B0044 | UFS_UECT | 32 | Host UIC Error Code Transport Layer |
112B0048 | UFS_UECDME | 32 | Host UIC Error Code DME |
112B004C | UFS_UTRIACR | 32 | UTP Transfer Request Interrupt Aggregation Control Register |
112B0050 | UFS_UTRLBA | 32 | UTP Transfer Request List Base Address |
112B0054 | UFS_UTRLBAU | 32 | UTP Transfer Request List Base Address Upper 32 Bits |
112B0058 | UFS_UTRLDBR | 32 | UTP Transfer Request List Door Bell Register |
112B005C | UFS_UTRLCLR | 32 | UTP Transfer Request List Clear Register |
112B0060 | UFS_UTRLRSR | 32 | UTP Transfer Request List Run Stop Register |
112B0064 | UFS_UTRLCNR | 32 | UTP Transfer Request List Completion Notification
Register |
112B0070 | UFS_UTMRLBA | 32 | UTP Task Management Request List Base Address |
112B0074 | UFS_UTMRLBAU | 32 | UTP Task Management Request List Base Address Upper 32 Bits |
112B0078 | UFS_UTMRLDBR | 32 | UTP Task Management Request List Door Bell Register |
112B007C | UFS_UTMRLCLR | 32 | UTP Task Management Request List Clear Register |
112B0080 | UFS_UTMRLRSR | 32 | UTP Task Management Request List Run Stop Register |
112B0090 | UFS_UICCMD | 32 | UIC Command |
112B0094 | UFS_UICCMDARG1 | 32 | UIC Command Argument 1 |
112B0098 | UFS_UICCMDARG2 | 32 | UIC Command Argument 2 |
112B009C | UFS_UICCMDARG3 | 32 | UIC Command Argument 3 |
112B00C0 | UFS_SYSTHRTL | 32 | SYS Throttling |
112B00C4 | UFS_OSYSR | 32 | Outstanding SYS Requests |
112B00C8 | UFS_XCNF | 32 | Extended Configuration |
112B00D0 | UFS_CDACFG | 32 | C-Port Direct Access Configuration |
112B00D4 | UFS_CDATX1 | 32 | C-Port Direct Access Transmit 1 |
112B00D8 | UFS_CDATX2 | 32 | C-Port Direct Access Transmit 2 |
112B00DC | UFS_CDARX1 | 32 | C-Port Direct Access Receive 1 |
112B00E0 | UFS_CDARX2 | 32 | C-Port Direct Access Receive 2 |
112B00E4 | UFS_CDASTA | 32 | C-Port Direct Access Status |
112B00F0 | UFS_LBMCFG | 32 | UPIU Loopback Configuration |
112B00F4 | UFS_LBMSTA | 32 | UPIU Loopback Status |
112B00FC | UFS_HCLKDIV | 32 | HCLK Divider |
112B0100 | UFS_CCAP | 32 | Crypto Capability |
112B0104 | UFS_0_CRYPTOCAP | 32 | Crypto Capability 0 |
112B0108 | UFS_1_CRYPTOCAP | 32 | Crypto Capability 1 |
112B010C | UFS_2_CRYPTOCAP | 32 | Crypto Capability 2 |
112B0110 | UFS_3_CRYPTOCAP | 32 | Crypto Capability 3 |
112B0114 | UFS_4_CRYPTOCAP | 32 | Crypto Capability 4 |
112B0130 | UFS_ADDR_SECURE_CAP | 32 | Encryption Secure Control capability |
112B0134 | UFS_ADDR_SECURE_MAP | 32 | Encryption Secure Control Map |
112B0144 | UFS_ADDR_XOUFS_ST | 32 | XOUFS Status |
112B0148 | UFS_ADDR_XOUFS_CNT | 32 | XOUFS Delay Count |
112B014C | UFS_MMIO_OTSD_CTRL | 32 | Dynamic Outstanding Control |
112B0150 | UFS_MMIO_QOS_CTRL | 32 | QoS Control Register |
112B0154 | UFS_MMIO_QOS_BUSY | 32 | QoS Busy Timing Counts |
112B0158 | UFS_MMIO_QOS_CNTS | 32 | QoS DBR Counts |
112B0500 | UFS_x_CRYPTOCFG_DW0 | 32 | Crypto Configuration x DW0 |
112B0504 | UFS_x_CRYPTOCFG_DW1 | 32 | Crypto Configuration x DW1 |
112B0508 | UFS_x_CRYPTOCFG_DW2 | 32 | Crypto Configuration x DW2 |
112B050C | UFS_x_CRYPTOCFG_DW3 | 32 | Crypto Configuration x DW3 |
112B0510 | UFS_x_CRYPTOCFG_DW4 | 32 | Crypto Configuration x DW4 |
112B0514 | UFS_x_CRYPTOCFG_DW5 | 32 | Crypto Configuration x DW5 |
112B0518 | UFS_x_CRYPTOCFG_DW6 | 32 | Crypto Configuration x DW6 |
112B051C | UFS_x_CRYPTOCFG_DW7 | 32 | Crypto Configuration x DW7 |
112B0520 | UFS_x_CRYPTOCFG_DW8 | 32 | Crypto Configuration x DW8 |
112B0524 | UFS_x_CRYPTOCFG_DW9 | 32 | Crypto Configuration x DW9 |
112B0528 | UFS_x_CRYPTOCFG_DW10 | 32 | Crypto Configuration x DW10 |
112B052C | UFS_x_CRYPTOCFG_DW11 | 32 | Crypto Configuration x DW11 |
112B0530 | UFS_x_CRYPTOCFG_DW12 | 32 | Crypto Configuration x DW12 |
112B0534 | UFS_x_CRYPTOCFG_DW13 | 32 | Crypto Configuration x DW13 |
112B0538 | UFS_x_CRYPTOCFG_DW14 | 32 | Crypto Configuration x DW14 |
112B053C | UFS_x_CRYPTOCFG_DW15 | 32 | Crypto Configuration x DW15 |
112B0540 | UFS_x_CRYPTOCFG_DW16 | 32 | Crypto Configuration x DW16 |
112B0544 | UFS_x_CRYPTOCFG_DW17 | 32 | Crypto Configuration x DW17 |
