Mechanical absorptive switches provide high reliability, repeatable high performance and internal terminations of input signals on the disconnected paths
Operation from DC to 18 GHz
Supports a wide range of RF test and signal routing applications, including 5G NR and WiFI 6E, with a single device
Break-before-make configuration
Prevents a momentary connection of the old and new signal paths, reducing the inconsistent tran- sient effects that could otherwise be observed during switching
USB & Ethernet control
USB HID and Ethernet (HTTP / Telnet) interfaces provide easy compatibility with a wide range of software setups and programming environments
Full software support
User friendly Windows GUI (graphical user interface) allows manual control straight out of the box, while the comprehensive API (application programming interface) with examples and instructions allows easy automation in most programming environments
