高性能AI智能模组——SM08 | 产品外观 |
| 产品特色 | 高性能 低功耗 高算力 最高工艺水平智能模组 | Item | Description | CPU | ♦ UMS9620W 4*A76@2.2GHz + 4*A55@2.0GHz3MB L3 或者 UMS9620S 1*A76@2.7GHz + 3*A76@2.3GHz+4*A55@2.1GHz3MB L3 | GPU | ♦ Mali-G57 MC4@650MHZ, ES3.0 46 fps 或者Mali-G57 MC4@850MHZ , ES3.0 60fps | NPU | ♦ 独立 IMG的NPU♦ 3.2TOPS 或者8TTOPS | Memory | eMCP/UMCP 4+64 6+128 8+256 三种配置 其中4+64和6+128 可以配合国产化 | WLAN | 2.4G/5G双频, 802.11a/b/g/n/ac/ax | BT | BT5.0(BR/EDR+BLE) | GNSS | GPS/Galileoe/GLONASS/Beidou(B1C) | OS | Android11或者Ubantu | Display | ♦ QHD+@60 fps♦ FHD+@120fps HDR10+, Dual MIPI | Camera | 48M@30 fps ZSL capture 最高达到50M | POWER | 3.5V-4.35V | Module Size | 43.0x43.0x2.8mm, 156Pin LCC + 92Pin LGA | Temperature | 负30度到正55度 | Interface | Description | LCD | 4-data lane, FHD 60fps | Camera | I2C controls, 4 lanes CSI1, support 24M, 4 lane CSI0, support 24M 支持四路同时摄像 | UART | Support, x3 | SPI/I2C/I2S | Support, x2/x8/x2 | SPEAKER | Support, x1 | RECEIVER | Support, x1 | EARPhone | Support, x1 | MIC | Support, x2(Analog), x4(Digital) | PCIE | Gen3 x1, 8Gbps | USB | 2.0 + 3.2 Gen2 | Antenna | 3PADS: GNSS Antenna, BT/WIFI antenna, FM antenna | Upgrade | USB/fota |
功能模块 | 管脚号 | SM08管脚名 (T760) | SM07(T710) | I/O | 描述 | 电源 | 73,74,75 | VBattery | | PI | 电池电源 | 99 | VDD1V85 | | PO | IO电源输出—— 固定1.8V | 97 | VDD2V8 | | PO | 电源2.8V—— 固定2.8V | 95 | VDDCAMA0 | | PO | MSCI0模拟电压输入 ——默认2.8V,200mA | 96 | VDDCAMD0 | | PO | MSCI0核电压输入—— 默认1.2V,200mA | 94 | VDDCAMA1 | | PO | MSCI1模拟电压输入 ——默认2.8V,200mA | 98 | VDDCAMD1 | | PO | MSCI1核电压输入—— 默认1.2V,100mA | 93 | VDDCAMIO | | PO | MSCI0/1 IO电压输入 ——默认1.8V | 190 | VDDCAMMOT0 | | PO | CAM 马达控制电压输 入——可调1.8~3.3V, 默认3V 400mA | 127 | VDDSDCORE | | PO | T卡供电电源 | 186 | VDDVIB | | PO | 马达控制输出 —— 1.8~3.3V,100mA | 189 | ★VDDCAMMOT1 | RESERVED//VDDLDO1 | PO | | 191 | VDDKPLED | | | 按键灯输出 | 192 | VBATBK | | PO | | | 1,8,15,26,37,52,68,72,76,79,84,90,100,103,116,119,121,134,149, 213,214,215,216,217, 218,219,220, 221,222,223,224,225, 226,227,228, | | PI | 地 | LED | | | | | | 指示灯 | 193 | RGB_IB0/R | | AI | 指示灯输入 | 194 | RGB_IB1/G | | AI | 指示灯输入 | 195 | RGB_IB2/B | | AI | 指示灯输入 | AUDIO | | | | | | 音频MIC | 92 | MIC_BIAS | | PO | 主MIC电源 | 80 | MIC1_P | | AI | 主MIC输入正极 | 81 | MIC1_N | | AI | 主MIC输入负极 | 91 | MIC2_BIAS | | PO | 辅MIC电源 | 82 | MIC2_P | | AI | 辅MIC输入正极 | 83 | MIC2_N | | AI | 辅MIC输入负极 | 音频耳机 | 86 | HP_MIC_IN_DET | | AI | 耳机MIC输入 | 89 | HP_L | | AO | 耳机左声道输出 | 87 | HP_R | | AO | 耳机右声道输出 | 88 | AMPG_VCOM | | GND | 耳机模拟参考地 | 85 | HP_L_INT/HP_DET | | AI | 耳机插入检测 | 音频听筒 | 187 | EAR_P | | AO | 听筒输出正极 | 188 | EAR_N | | AO | 听筒输出负极 | 音频喇叭 | 77 | PAOUT_P | | AO | 喇叭输出正极 | 78 | PAOUT_N | | AO | 喇叭输出负极 | CSI接口 | | | | | | | | VDDCAMA0 | | PO | 主后摄模拟电源 | | VDDCAMCORE0 | | PO | 主后摄数字电源 | | VDDCAMIO | | PO | 主后摄IO电源 | | VDDCAMMOT0 | | PO | 主后摄对焦马达电源 | CSI 1CPHY&DPHY | 47 | CAM_PWDN1/GPIO4 | CAM_PWDN1 | DO | 主后摄关断信号 | 46 | CAM_RST1/GPIO40 | CAM_RST1 | DO | 主后摄复位信号 | 42 | CAM_SCL0/GPIO51 | CAM_SCL0 | DO | I2C时钟信号 | 43 | CAM_SDA0/GPIO52 | CAM_SDA0 | IO | I2C数据信号 | 38 | CAM_MCLK1/GPIO36 | CAM_MCLK1 | DO | 主后摄时钟信号 | 19 | MCSI1_CKP_B1 | MCSI1_CLK_N | AO | MIPI时钟信号 | 18 | MCSI1_CKN_C1 | MCSI1_CLK_P | AO | 25 | MCSI1_DP0_A0 | MCSI1_DATA0_ | P AI | 主后摄MIPI信号 | 24 | MCSI1_DN0_B0 | MCSI1_DATA0_ | N AI | 23 | MCSI1_DP1_C0 | MCSI1_DATA1_ | P AI | 22 | MCSI1_DN1_A1 | MCSI1_DATA1_ | N AI | 17 | MCSI1_DP2_A2 | MCSI1_DATA2_ | P AI | 16 | MCSI1_DN2_B2 | MCSI1_DATA2_ | N AI | 21 | MCSI1_DP3_C2 | MCSI1_DATA3_ | P AI | 20 | MCSI1_DN3_NC | MCSI1_DATA3_ | N AI | | | | | | | CSI 2DPHY | | VDDCAMA1 | | PO | 副后摄模拟电源 | | VDDCAMCORE1 | | PO | 副后摄数字电源 | | VDDCAMIO | | PO | 副后摄IO电源 | | VDDCAMMOT | | PO | 副后摄对焦马达电源 | 170 | CAM_PWDN2/GPIO4 | CAM_PWDN2 | DO | 关断信号2 | 169 | CAM_RST2/GPIO41 | CAM_RST2 | DO | 复位信号2 | | | | DO | I2C时钟信号 | | | | IO | I2C数据信号 | 168 | CAM_MCLK2/GPIO37 | CAM_MCLK2 | DO | 时钟信号2 | 179 | MCSI2_CLK_P | MCSI2_CLK_P | AO | MIPI时钟信号 | 180 | MCSI2_CLK_N | MCSI2_CLK_N | AO | 171 | MCSI2_CLK1_P# | MCSI0_CLK1_P | | 预留, 与MCSI0_DATA2/ | 172 | MCSI2_CLK1_N# | MCSI0_CLK1_N | | 174 | MCSI2_DATA0_P | MCSI2_DATA0_ | P AI | MIPI信号 | 173 | MCSI2_DATA0_N | MCSI2_DATA0_ | N AI | 181 | MCSI2_DATA1_P | MCSI2_DATA1_ | P AI | 182 | MCSI2_DATA1_N | MCSI2_DATA1_ | N AI | 178 | MCSI2_DATA2_P | MCSI2_DATA2_ | P AI | 177 | MCSI2_DATA2_N | MCSI2_DATA2_ | N AI | 175 | MCSI2_DATA3_P | MCSI2_DATA3_ | P AI | 176 | MCSI2_DATA3_N | MCSI2_DATA3_ | N AI | | | | | | | CSI 0CPHY&DPHY | | VDDCAMA1 | | PO | 前摄模拟电源 | | VDDCAMCORE1 | | PO | 前摄数字电源 | | VDDCAMIO | | PO | 前摄IO电源 | | VDDCAMMOT | | PO | 前摄对焦马达电源 | 45 | CAM_PWDN0 | CAM_PWDN0 | DO | 关断信号0 | 44 | CAM_RST0 | CAM_RST0 | DO | 复位信号0 | 39 | CAM_MCLK0 | CAM_MCLK0 | DO | | 40 | CAM_SCL1 | CAM_SCL1 | DO | I2C1时钟信号 | 41 | CAM_SDA1 | CAM_SDA1 | IO | I2C1数据信号 | 33 | MCSI0_CKP_B1 | MCSI0_CLK_P | AO | MIPI时钟信号 | 34 | MCSI0_CKN_C1 | MCSI0_CLK_N | AO | 36 | MCSI0_DP0_B0 | MCSI0_DATA0P_ | AI | | 35 | MCSI0_DN0_A0 | MCSI0_DATA0N_ | AI | 32 | MCSI0_DP1_C0 | MCSI0_DATA1P_ | AI | 31 | MCSI0_DN1_A1 | MCSI0_DATA1N_ | AI | | 28 |
| MCSI0_DATA2P_ | AI | MIPI信号 | 27 | MCSI0_DN2_B2 | MCSI0_DATA2N_ | AI | 29 | MCSI0_DP3_C2 | MCSI0_DATA3P_ | AI | 30 | MCSI0_DN3_NC | MCSI0_DATA3N_ | AI | PCIE3 | | | | | | PCIE3接 口 | 151 | AP_PCIE3_RST/GPIO154 | | | | 152 | AP_PCIE3_WAKE/GPIO156 | | | | 150 | AP_PCIE3_CLKREQ/GPIO155 | | | | 13 | AP_PCIE3_TXP | | | | 14 | AP_PCIE3_TXN | | | | 11 | AP_PCIE3_RXP | | | | 12 | AP_PCIE3_RXN | | | | 9 | AP_PCIE3_CLKP | | | | 10 | AP_PCIE3_CLKN | | | | USB2.0/3.0 | | | | | | Type -C接口 | 69,70,71 | VCHG | | PI/PO | 仅作为充电检测, 无充 电功能和OTG输出功能 | 101 | AP_USB_DP | | IO | USB2.0数据正信号 | 102 | AP_USB_DM | | IO | USB2.0数据负信号 | 143 | AP_SSTX0_P | | DI | USB3.0数据线 | 144 | AP_SSTX0_N | | DI | 141 | AP_SSTX1_P | | DI | 142 | AP_SSTX1_N | | DI | 139 | AP_SSRX0_P | | DO | 140 | AP_SSRX0_N | | DO | 137 | AP_SSRX1_P | | DO | 138 | AP_SSRX1_N | | DO | 136 | USB_CCA | | DI | 检测脚1 | 135 | USB_CCB | | DI | 检测脚2 | 206 | ★ USB_SBU2 | (RESERVED) | DI | | 207 | ★ USB_SBU1 | (RESERVED) | DI | | DSI(LCM) | | | | | | MDSI0 | | VDD1V85 | | PO | 1.8V IO电源 | | VDD2V8 | | PO | 2.8V电源 | 125 | LCM_BL_PWM/GPIO10 | LCM_BL_PWM/GPIO123 | DO | 背光亮度调节PWM控制 信号 | 115 | LCM_RSTN/GPIO11 | LCM_RSTN/GPIO50 | DO | 复位信号 | 114 | LCM_FMARK/GPIO12 | LCM_FMARK/GPIO51 | DI | Tearing Effect 信号 | 106 | LCM_CLK_P | | AO | MIPI时钟信号 | 107 | LCM_CLK_N | | AO | 112 | LCM_DATA0_P | | AO | MIPI数据信号 | 113 | LCM_DATA0_N | | AO | 108 | LCM_DATA1_P | | AO | 109 | LCM_DATA1_N | | AO | 104 | LCM_DATA2_P | | AO | 105 | LCM_DATA2_N | | AO | | 111 | LCM_DATA3_P | | AO | | 112 | LCM_DATA3_N | | AO | MDSI1 | 6 | ★ MDSI1_CLK_P | | AO | MIPI时钟信号 | 7 | ★ MDSI1_CLK_N | | AO | 2 | ★ MDSI1_DATA0_P | | AO | DSI1数据信号 | 3 | ★ MDSI1_DATA0_N | | AO | 4 | ★ MDSI1_DATA1_P | | AO | 5 | ★ MDSI1_DATA1_N | | AO | 153 | ★ MDSI1_DATA2_P | | AO | 154 | ★ MDSI1_DATA2_N | | AO | 155 | ★ MDSI1_DATA3_P | | AO | 156 | ★ MDSI1_DATA3_N | | AO | CTP | | | | | | TPI2C | | VDD1V85 | | PO | 1.8V IO电源 | | VDD2V8 | | PO | 2.8V电源 | 50 | CTP_RST/GPIO14 | CTP_RST/GPIO145 | DO | 复位信号 | 51 | CTP_INT/GPIO13 | CTP_INT/GPIO144 | DI | 中断信号 | 49 | CTP_SCL3/GPIO16 | CTP_SCL3/GPIO147 | DO | I2C时钟信号 | 48 | CTP_SDA3/GPIO15 | CTP_SDA3/GPIO144 | IO | I2C数据信号 | I2C接口 *5 | | | | | | I2C接口 | | I2C0_SCL | | DO | 摄像头I2C0时钟信号 | | I2C0_SDA | | IO | 摄像头I2C0数据信号 | | I2C1_SCL | | DO | 摄像头I2C1时钟信号 | | I2C1_SDA | | IO | 摄像头I2C1数据信号 | 63 | I2C2_SCL/GPIO122 | I2C2_SCL | DO | sensor I2C2时钟信号 | 64 | I2C2_SDA/GPIO123 | I2C2_SDA | IO | sensor I2C2数据信号 | | CTP_SCL3/GPIO16 | | DO | CTP I2C时钟信号 | | CTP_SDA3/GPIO15 | | IO | CTP I2C数据信号 | 234 | I2C4_SCL/GPIO113 | I2C4_SCL | DO | I2C4时钟信号 | 233 | I2C4_SDA/GPIO114 | I2C4_SDA | IO | I2C4数据信号 | 184 | ★CHG_SCL6/GPIO129 | I2C6_SCL(RESE RVED) | DO | 用于外部充电IC I2C时 钟信号 | 183 | ★CHG_SDA6/GPIO13 | I2C6_SDA(RESE RVED) | IO | 用于外部充电IC I2C数 据信号 | 200 | 0I2C8_SCL/GPIO55 | | IO | | 201 | I2C8_SDA/GPIO56 | | IO | | 198 | I2C9_SCL/GPIO157 | SD2_D0/GPIO136 | IO | | 199 | I2C9_SDA/GPIO158 | SD2_D1/GPIO137 | IO | | | I2C7_SCL | | DO | 模组内部DCDC I2C时钟 信号 | | I2C7_SDA | | IO | 模组内部DCDCI2C4数 据信号 | I2S接口 *2 | | | | | | IIS3接口 | 238 | I2S3_SDI/GPIO191 | I2S3_SDI/GPIO24 | DI | IIS3 | 239 | I2S3_SDO/GPIO192 | I2S3_SDO/GPIO25 | DO | IIS3 | 237 | I2S3_SCLK/GPIO194 | I2S3_SCLK/GPIO27 | DO | IIS3 | | 240 | I2S3_LRCK/GPIO193 | I2S3_LRCK/GPIO26 | DO | IIS3 | IIS1接口 | 205 | ★ IIS1_DI/GPIO109 | (RESERVED) | DO | IIS1 | 203 | ★IIS1_CLK/GPIO111/ | (RESERVED) | DO | IIS1 | 202 | ★IIS1_LRCK/GPIO112 | (RESERVED) | IO | IIS1 | 204 | ★ IIS1_DO/GPIO110 | (RESERVED) | IO | IIS1 | SDIO接 口*1 | | | | | | T卡接口 SDIO1 | | VDDSDCORE | | PO | T卡供电电源 | 132 | TF_SD0_CMD | | DO | T卡控制信号 | 133 | TF_SD0_CLK0 | | DO | T卡时钟信号 | 131 | TF_SD0_D0 | | IO | T卡数据信号 | 130 | TF_SD0_D1 | | IO | 129 | TF_SD0_D2 | | IO | 128 | TF_SD0_D3 | | IO | 65 | TF_DET/GPIO138 | | DI | T卡检测信号 | SPI接口 *2 | | | | | | SPI0接口 | 57 | SPI0_DO/GPIO107 | | DO | SPI0输出信号 | 56 | SPI0_DI/GPIO106 | | DI | SPI0输入信号 | 58 | SPI0_CSN/GPIO108 | | DO | SPI0片选信号 | 55 | SPI0_CLK/GPIO105 | | DO | SPI0时钟信号 | SPI2接口 | 161 | SPI2_DO | | DO | SPI2输出信号 | 162 | SPI2_DI | | DI | SPI2输入信号 | 163 | SPI2_CSN | | DO | SPI2片选信号 | 164 | SPI2_CLK | | DO | SPI2时钟信号 | UART接 口*4 | | | | | | | 54 | UART1_TXD | | DO | 串口1发送数据,对地 短路时用于下载 | 53 | UART1_RXD/GPIO143 | | DI | 串口1接收数据 | 211 | UART2_TXD/GPIO140 | | DO | 串口2发送数据 | 212 | UART2_RXD/GPIO141 | | DI | 串口2接收数据 | 62 | UART5_TXD/I2C5_S CL/GPIO175 | | DO | 串口5发送数据 | 61 | UART5_RXD/I2C5_S DA/GPIO176 | | DI | 串口5接收数据 | 209 | UART6_TXD/GPIO183 | | DO | 串口6发送数据 | 210 | UART6_RXD/GPIO184 | | DI | 串口6接收数据 | 59 | UART7_TXD/GPIO181 | | DO | 串口7接收数据 | 60 | UART7_RXD/GPIO182 | | DI | 串口7发送数据 | | UART0_TXD | | DO | 内置连接WCN_UART0(WIFI) | | UART0_RXD | | DI | | UART0_CTS | | DI | | UART0_RTS | | DO | | UART4_TXD | | DO | 内置连接WCN_UART1(GPS) | | UART4_RXD | | DI | | UART4_CTS | | DI | | | UART4_RTS | | DO | | 按键接 | | | | | | 按键接口 | 123 | PBINT | | DI | 开关机按键信号UMP9620 | 122 | EXTRSTN | | DI | 按键输入信号,默认音 量(对地) UMP9620 | 167 | KEYIN0 | | DI | 按键输入信号, 默认音 量加和下载键功能(对 | 166 | KEYIN1 | | DI | 按键输入信号 | 236 | KEYIN2/GPIO9 | | DI | 按键输入信号 | 165 | KEYOUT0/GPIO125 | | DO | 按键输出信号(做矩阵键 盘用) | 235 | KEYOUT1/GPIO124 | | DO | 按键输出信号(做矩阵键 盘用) | GNSS/W IFI/FM接口 | | | | | | RF接口 | 117 | WIFI5G&2.4G | | AI | WIFI | 120 | GNSS | | AI | GNSS | 118 | FM_ANT | | AI | FM天线 | ADC接 | | | | | | ADC接口 | 124 | BAT_TEMP_ADC | | AI | 电池温度检测UMP9620 | | VBAT_SENSE | | AI | 电池电压检测 核心板上 与BATTER脚已连接 | 66 | SENSE_P | | AI | Fuel gage检测 | 67 | SENSE_N | | AI | Fuel gage检测 | | BOARD_TEMP_ADC_ AP/ADCI1 | | AI | 模组内部温度检测 | 242 | ADCI2 | | AI | | 243 | ADCI3 | | AI | | 244 | CHG_TEMP_ADCI4 | | AI | 外部充电温度检测 | | BOARD_ID_ADC5 | | AI | 内部连接 | | BOARD_ID_ADC6 | | AI | 内部连接 | GPIO接 口 | | | | | | GPIO/SI M接口 | | | | | | GPIO/SIM | 148 | GPIO2(SIM0_DA) | | IO | SIM1卡数据信号 | 147 | GPIO3(SIM0_RST) | | DO | SIM1卡复位信号 | 146 | GPIO1(SIM0_CLK) | | DO | SIM1卡时钟信号 | 145 | GPIO136(SIM0_DET) | | DI | SIM1卡检测信号 | 245 | GPIO5(SIM1_DA) | | IO | SIM2卡数据信号 | 246 | GPIO4(SIM1_RST) | | DO | SIM2卡复位信号 | 247 | GPIO6(SIM1_CLK) | | DO | SIM2卡时钟信号 | 248 | GPIO137(SIM1_DET) | | DI | SIM2卡检测信号 | | 208 | GPIO32/PWM | | DI/DO | | 241 | GPIO195/CLK_AUX2 | | DI/DO | | 185 | ★ CHG_EN | | DO | 外部充电IC 控制信号 UMP9620 | 157 | DMIC1_CLK/GPIO187 | | DI/DO | | 其他接口 | 158 | DMIC1_DAT/GPIO188 | | DI/DO | | 159 | DMIC0_CLK/GPIO189 | | DI/DO | | 160 | DMIC0_DAT/GPIO190 | | DI/DO | | SDIO 1 | 197 | GPIO151/SD1_CMD | SD2_CMD/GPIO135 | DO | 复用SDIO1_CMD | 126 | GPIO156/LCM1_RST N/SD1 DO | | DI/DO | 复用SDIO1 D0//LCM1 RST | 196 | GPIO153/LCM1_TE/ SD1_D1 | SD2_CLK/GPIO134 | DO | 复用SDIO1_D1//LCM1_TE | 151 | AP_PCIE3_RST/GPIO 154/SD1 CLK | SD2_D0/GPIO136 | IO | 复用SDIO1_CLK | 152 | AP_PCIE3_WAKE/GP IO156/SD1_D3 | SD2_D1/GPIO137 | IO | 复用SDIO1_D3 | 150 | AP_PCIE3_CLKREQ/ GPIO155/SD1 D2 | | IO | 复用SDIO1_D2 | | | | IO | |
展锐5G-UMS9620W(T760)核心板/开发板/方案定制
https://bbs.16rd.com/shop_product-1-1667.html
技术咨询或项目定制,请联系:13316559917(微信同号,加号请备注(展讯定制))
