Mechanical reflective switches provide high reliability and repeatable performance
Operation from DC to 40 GHz
Supports a wide range of RF test and signal routing applications, including 2G, 3G, 4G and 5G, with a single device
Break-before-make configuration
Prevents a momentary connection of the old and new signal paths, reducing the inconsistent transient effects that could otherwise be observed during switching
USB & Ethernet control
USB HID and Ethernet (HTTP / Telnet) interfaces provide easy compatibility with a wide range of software setups and programming environments
Full software support
User friendly Windows GUI (graphical user interface) allows manual control straight out of the box, while the com- prehensive API (application programming interface) with examples and instructions allows easy automation in most programming environments
