Transfer switches provide a simple DPDT switch application (2 input to 2 output switch matrix) and are a useful build- ing block in much larger switch matrices
Fail-safe design
The switches revert to a known default state when the DC supply is reMOVed, allowing their use in systems that must continue to operate safely in the event of power failure
Break-before-make configuration
Prevents a momentary connection of the old and new signal paths, reducing the inconsistent transient effects that could otherwise be observed during switching
USB & Ethernet control
USB HID and Ethernet (HTTP / Telnet) interfaces provide easy compatibility with a wide range of software setups and programming environments
Full software support
User friendly Windows GUI (graphical user interface) allows manual control straight out of the box, while the com- prehensive API (application programming interface) with examples and instructions allows easy automation in most programming environments
