GDEY029F51H是一个有源矩阵TFT基板上的反射式电泳技术显示模块。该面板能够显示黑色、白色、黄色和红色图像,这取决于所使用的相关查询表。面板上的电路包括一个集成的门和源驱动器、定时控制器、振荡器、DC-DC升压电路以及存储帧缓冲器和查找表的存储器1。Over View表,以及控制VCOM和BORDER设置的附加电路。
2.功能
⚫突出红色和黄色
⚫高对比度
⚫高反射率
⚫超宽视角
⚫超低功耗
⚫纯反射模式
⚫双稳定显示
⚫反拉式的前表面
⚫低电流深度睡眠模式
⚫在
芯片显示屏上
⚫存储在片上OTP中的波形
⚫可串行外围界面可用
⚫芯片振荡器
⚫用于生成VCOM,门和源驱动电压的芯片助推器和调节器控制
I2C信号主界面以读取外部温度传感器
⚫在COG软件包中可用
3.机械规格
Parameter | Specifications | Unit | Remark |
Screen Size | 2.9 | Inch | |
Display Resolution | 168(H)*384 (V) | Pixel | Dpi:144 |
Active Area | 29.57*6 7.58 | mm | |
Pixel Pitch | 0.176*0.176 | mm | |
Pixel Configuration Re | ctangle | | |
Outline Dimension 35 | .57(H)*79.98(V) *1.0(D) | mm | |
Weight 5. | 29±0.5 | g | |
6.电特性
6.1绝对最大评分
Parameter | Symbol | Rating | Unit |
Logic supply voltage | VDD, AVDD,VDDIO, VDD1,VPP | -0.3 to +6.0 | V |
Logic Input voltage | VI | -0.3 to VDDIO+0.3 | V |
Operating Temp range | TOPR | 0 to +40 | ºC |
Storage Temp range | TSTG | -25 to +60 | ºC |
Optimal Storage Temp | TSTGo | 23±2 | ºC |
Optimal Storage Humidity | HSTGo | 55±10 | %RH |
6.2面板DC特性
Parameter | Symbol | Conditions | Applica ble pin | Min. | Typ. | Max | Units |
Single ground | VSS | - | | - | 0 | - | V |
Logic supply voltage | VIO | - | VIO | 2.3 | 3.3 | 3.6 | V |
Core logic voltage | VDD | | VDD | 2.3 | 3.3 | 3.6 | V |
High level input voltage | VIH | - | - | 0.7VIO | - | VIO | V |
Low level input voltage | VIL | - | - | GND | - | 0.3VDD | V |
High level output voltage | VOH | IOH = 400uA | - | VIO -0.4 | - | - | V |
Low level output voltage | VOL | IOL = -400uA | - | GND | - | GND
+0.4 | V |
Typical power | PTYP | VCI =3.3V | - | - | 9.9 | - | mW |
Deep sleep mode | PSTPY | VCI =3.3V | - | - | 0.003 | - | mW |
Typical operating current | Iopr_VCI | VCI =3.3V | - | - | 3.0 | - | mA |
Image update time | - | 25 ºC | - | - | 25 | - | sec |
Stand-by current | Ist_VDD | | - | - | 1 | 5 | uA |
