问题描述(Issue Description)
[CTS\GTS\VTS…Test Step] :
− cd Android-cts/tools
− ./cts-tradefed
− run cts –m
[CTS/GTS/VTS Version] : CTS 11 frc
[GMS/GSI Version]: R_beta
[Security Patch]: Update to 202008
[Testing Result]:
4541 cases failed.
The entire CtsMediaBitstreamsTestCases module failed.
问题分析(Analysis)
1、The failure of pulling /storage/emulated/0/Android/data from SC77311E11098191210 to /tmp cause this
module failed.
07-08 20:14:04 W/NativeDevice: Failed to pull
/storage/emulated/0/Android/data/android.media.cts.bitstreams.app/cache/MediaBitstreamsDeviceSideTest1763356239215622542.txt from SC77311E11098191210 to /tmp/MediaBitstreamsDeviceSideTest1763356239215622542_4051496318151231494.txt. message Remote object doesn't exist!
2、A Google request for depreted sdcardfs commit results in unauthorized access to the associated path by adb shell.
/dev/block/dm-11 on /storage/emulated/0/Android/data type f2fs
(rw,dirsync,lazytime,seclabel,nosuid,nodev,noatime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=reuse,fsync_mode=posix)
s9863a3h10:/sdcard/Android # ls –lZ total 9
drwxrws--x 11 media_rw ext_data_rw u:object_r:media_rw_data_file:s0 3452 2020-07-09 22:53 data
结果
谷歌反馈
信息
谷歌确认此弃权
NO
ACtually. It's on
"CTS/VTS R2+ Dev" as
it's a CTS fix and it might
take a day to hit the PAB.
please check later today.
Google Issue:
https://partnerissuetracker.corp.google.com/issues/161105343
结果
详情(如果结果是YES)
使用来自 Partner Android Build (PAB) dashboard 的最新 CTS/GSI/VT S dev builds,来验证失败的测试,测试失败不再发生。
YES
Test Date:
2020 Aug 19
Test Case:
run cts –m CtsMediaBitstreamsTestCases
CTS/VTS/CTS-On-GSI dev Build Number:
build#6752613
Build Created date:
2020 Aug 19
