Broadcom® HSD9-B170 是一款顶视型光电二极管,采用行业标准的 2.0 mm *1.3 mm 占地面积。这种坚固而高质量的光电二极管用途广泛,易于使用。.
它具有700纳米至1100纳米的宽光谱灵敏度,峰值灵敏度为940纳米。再加上其快速的响应时间,该产品是消费和工业领域各种应用的理想解决方案,如家用电器、光幕和烟雾探测器。
该产品的半灵敏度角度为±75度。它是用黑色环氧树脂建造的,可以过滤掉可见光,这就减少了来自可见光范围的不需要的噪音。它与工业标准的自动机器贴装和红外回流焊兼容。
硅光电二极管
0805脚印
黑色环氧树脂
700纳米至1100纳米的宽光谱范围内的灵敏度
峰值灵敏度为940 nm
半数灵敏度的角度为±75度
办公室自动化
烟雾探测器
光幕
图1:包装图
图1:包装图
绝对最大额定值
Parameter | Rating | Unit | Reverse Voltage | 30 | V | Power Dissipation | 150 | mW | Operating Temperature Range | –40 to +85 | °C | Storage Temperature Range | –40 to +100 | °C |
光学和电气特性(TA = 25°C)
Parameter | Value | Unit | Test Condition | Min. | Typ. | Max. | Reverse Light Current, Ira | 1.5 | 2.5 | — | μA | Ee = 1 mW/cm2, λ = 940 nm, VR = 5V | Wavelength of Peak Sensitivity, λS max | — | 940 | — | nm | — | Spectral Range of Sensitivity, λ0.1 | 700 | — | 1100 | nm | — | Angle of Half Sensitivity, φ | — | ±75 | — | ° | — | Reverse Dark Current, Iro | — | — | 10 | nA | Ee = 0 mW/cm2, VR = 10V | Open Circuit Voltage, VOC | — | 420 | — | mV | Ee = 1 mW/cm2, λ = 940 nm | Short Circuit Current, ISC | — | 2.5 | — | μA | Ee = 1 mW/cm2, λ = 940 nm | Temperature Coefficient of VOC, TCVOC | — | –2.9 | — | mV/°C | Ee = 1 mW/cm2, λ = 940 nm,
+25°C to Top max | Temperature Coefficient of ISC, TCISC | — | 0.042 | — | %/°C | Ee = 1 mW/cm2, λ = 940 nm,
+25°C to Top max | Forward Voltage, VF | — | 1.23 | — | V | IF = 100 mA | Diode Capacitance, Co | — | 3 | — | pF | VR = 0V, Ee = 0 mW/cm2, f = 1 MHz |
