SYMBOL | PARAMETER | CONDITIONS | MIN | TYP | MAX | UNITS |
Input Electrical Specifications |
Voo | Supply Voltage Range | | 3.0 | | 5.5 | V |
Icc | Quiescent current (la)(1) | Voo =3.3V, Vin =500mV,no load | | 34.5 | 42.8 | mA |
Vop = 5.0V, Vin =500mV,no load | | 45 | 55.6 | mA |
Vous | Output Level Shift Voltage | Vin=0V, no load, input referred | 54 | 80 | 124 | mV |
ICLAMP-CHG | Clamp Charge Current | ViN= VCLAMP- 100mV | -1.5 | -1.7 | | mA |
IcuAMP-DCHG | Clamp Discharge Current | Vin=500mV | 1.5 | 2.0 | 5.1 | μA |
VcLAMP | Input Voltage Clamp | IiN=-1mA | -40 | 0 | +40 | mV |
AV | Voltage Gain | Vin=0.5V,1V or 2V
RL=150Q to GND | 5.91 | 6.01 | 6.03 | dB |
PSRR | Power Supply Rejection Ratio | △Voo =3.3V to 3.6V | | 57 | | dB |
△Voo =5.0V to 5.5V,50Hz,VN=0.7V | | 61 | | dB |
VoH | Output Voltage High Swing | Vin=3V,R∠=75Q to GND (dual load) | | 3.18 | | V |
VoL | Output Voltage Low Swing | Vin=-0.3V,RL=75Q | | 0.05 | | V |
lsc | Short-circuit current | Vin=2V, output to GND through 10Ω | 65 | | | mA |
Vin=100mV, output short to Vop | 65 | | | mA |
AC Electrical Specifications |
f1dB | -1dB Bandwidth | RL=150Ω | 53.1 | 63.2 | 72.9 | MHz |
f3dB | -3dB Bandwidth | RL=150Q | 63.7 | 71.5 | 80.1 | MHz |
Att+48MHz | Stop Band Attenuation | f=148MHz | 34 | 39 | | dB |
SR | Slew Rate | 2V output step, 80% to 20% | | 300 | | V/us |
dG | Differential Gain | Video input range 1V | | 0.1 | 1 | % |
dP | Differential Phase | Video input range 1V | | 0.3 | 0.6 | o |
THD | Total Harmonic Distortion | f=10MHz, Vour=1.4Vpp | | 0.15 | | % |
f=22MHz, Vour=1.4Vpp | | 0.6 | | % |
D/DT | Group Delay Variation | f=100kHz to 27MHz | | 2.5 | | ns |
f=100kHz to 60MHz | | 6.0 | | ns |
tpo | PrOPAgation Delay | Maximum delay from input to output:
(100kHz to 60MHz) | | 11.0 | 18.0 | ns |
XTALK | Channel Crosstalk | f=1MHz,Vour=1.4Vpp | -68 | -74 | | dB |
SNR | Signal-to-Noise Ration | f=100kHz to 30MHz | | 67 | | dB |
f=100kHz to 60MHz | | 64 | | dB |
RouT AC | Output lmpedance | f=10MHz | | 0.5 | | Q |
