- 低导通电阻:2 Ω
- 低阈值:2 V(典型值)
- 低输入电容:25 pF
- 快速开关速度:25 ns
- 低输入和输出漏电
- TrenchFET® 功率 MOSFET
- 2000 V ESD 保护
优点
- 低偏移电压
- 低电压运行
- 无需缓冲器即可轻松驱动
- 高速电路
- 低误差电压
- 直接逻辑级接口: TTL/CMOS
- 驱动器
继电器、电磁阀、灯、锤子、显示器、存储器、晶体管等
- 电池供电系统
- 固态继电器
订购信息
ORDERING INFORMATION | Package | SOT-23 | Lead (Pb)-free | 2N7002K-T1-E3 | Lead (Pb)-free and halogen-free | 2N7002K-T1-GE3 |
绝对最大额定值(TA=25℃,除非另有说明) | PARAMETER | SYMBOL | LIMIT | UNIT | Drain-source voltage | Vos | 60 | V | Gate-source voltage | Vcs | 100
±20 | Continuous drain current(TJ =150°C)b | TA=25C | o | 0.3 | A | TA= 100℃ | 0.19 | Pulsed drain current a | DM | 0.8 | Power dissipation b | TA=25°C | Po | 0.35 | W | TA=100C | 0.14 | Maximum junction-to-ambient b | RthJA | 350 | C/W | Operating junction and storage temperature range | TJ, stg | -55 to+150 | ℃ |
- 215.53 KB
- Vishay 2N7002K 2Ω N沟道60V(D-S)MOSFET datasheet
