Parameter | Path | Condition | Min | Typ | Max | Unit |
Operating frequency |
| 9 k |
| 18 G | Hz |
Insertion loss | RFC-RFX | 9 kHz-10 MHz
10-3000 MHz
3000-7500 MHz
7500-10000 MHz
10000-13500 MHz
13500-16000 MHz
16000-18000 MHz |
| 0.70
1.20
1.65
2.10
2.30
3.10
4.10 | 0.85
1.50
2.05
2.55
2.80
3.60
4.70 | dB
dB
dB
dB
dB
dB
dB |
Isolation | RFX-RFX | 9 kHz-10 MHz
10-3000 MHz
3000-7500 MHz
7500-10000 MHz
10000-13500 MHz
13500-16000 MHz
16000-18000 MHz | 80
53
46
41
36
31
27 | 90
55
48
43
38
33
29 |
| dB
dB
dB
dB
dB
dB
dB |
Isolation | RFC-RFX | 9 kHz-10 MHz
10-3000 MHz
3000-7500 MHz
7500-10000 MHz
10000-13500 MHz
13500-16000 MHz
16000-18000 MHz | 78
54
41
36
31
27
24 | 90
55
42
38
32
28
25 |
| dB
dB
dB
dB
dB
dB
dB |
return loss
(active and common port) | RFC-RFX | 9 kHz-10 MHz
10-3000 MHz
3000-18000 MHz |
| 22
15
14 |
| dB
dB
dB |
Return loss
(terminated port) | RFX | 9 kHz-18000 MHz |
| 14 |
| dB |
Input 0.1dB compression point³ | RFC-RFX |
| Fig.4 |
| dBm |
Input IP2 | RFC-RFX | 30-18000 MHz |
| 113 |
| dBm |
Input IP3 | RFC-RFX | 30-18000 MHz |
| 59 |
| dBm |
Settling time |
| 50% CTRL to 0.05 dB final value |
| 2 | 3 | μs |
Switching time |
| 50% CTRL to 90% or 10% of final value |
| 500 | 800 | ns |
