Parameter | Value | Unit |
Input voltage | AC100 to AC240±10%(50 Hz/60 Hz) | V |
Power consumption | 25 | VA |
Output | Diode bias
voltage | Variable output voltage range | 0 to±500 | V |
Output current | Max. | 500 | uA |
Load regulation | Typ. | ±0.01 | % |
Ripple / Noise (p-p) | Typ. | 0.003 | % |
Connector | LEMO (ERN.00.250.CTL) | |
High voltage | Variable output voltage range | 0 to -8500 | |
Output current | Max. | 16 | uA |
Load regulation | Typ. | 50 | V |
Ripple / Noise (p-p) | Typ. | 50 | mV |
Connector | AMP 5-830395-1 | |
Fuse | 250 V, 1 A | |
Size (W×H×D) | 260×55 ×205 | mm |
Operating ambient temperature | +5 t0+40 | ℃ |
Operating ambient humidity | Below 80 | % |
Storage temperature | -20 to +50 | ℃ |
Storage humidity | Below 80 | % |
Place to be used (environment) | Indoor | |
Weight | 1.73 | kg |
