- TrenchFET® V 代功率 MOSFET
- 极低的 RDS x Qg 功率因数 (FOM)
- 针对最低 RDS x Qoss FOM 进行调谐
- 通过 100% Rg 和 UIS 测试
- 材料分类:有关
- 同步整流
- 原边开关
- 直流/直流转换器
- 电源
- 电机驱动控制
产品摘要 | Vps (V) | 100 | Rps(on)max.(Q)at Vas =10 V | 0.0105 | RpS(on)max.(Q)at Vas =7.5 V | 0.0124 | Qg typ.(nC) | 11.2 | lb(A)a | 55.9 | Configuration | Single |
ORDERING INFORMATION | Package | PowerPAK 1212-8S | Lead (Pb)-free and halogen-free | SiSS5108DN-T1-GE3 |
ABSOLUTE MAXIMUM RATINGS (TA=25°C,unless otherwise noted) | PARAMETER | SYMBOL | LIMIT | UNIT | Drain-source voltage | VDs | 100 | V | Gate-source voltage | Vgs | ±20 | Continuous drain current (TJ=150 ℃ | Tc =25℃ | b | 55.9 | A | Tc=70 ℃ | 44.7 | TA=25℃ | 15.4 b,c | TA=70 ℃ | 12.3 b,c | Pulsed drain current (t =100 μs | DM | 120 | Continuous source-drain diode current | Tc=25 ℃ | ls | 59.8 | TA=25 ℃ | 4.5 b,c | Single pulse avalanche current | L=0.1 mH | lAs | 20 | Single pulse avalanche energy | EAs | 20 | mJ | Maximum power dissipation | Tc=25℃ | PD | 65.7 | W | Tc=70 ℃ | 42.1 | TA=25 ℃ | 5 b,c | TA=70 ℃ | 3.2 b,c | Operating junction and storage temperature range | TJ,Tstg | -55 to +150 | ℃ | Soldering recommendations (peak temperature)d,e |
| 260 |
THERMAL RESISTANCE RATINGS | PARAMETER | SYMBOL | TYPICAL | MAXIMUM | UNIT | Maximum junction to ambient b | t≤10 s | RthJp | 20 | 25 | °C/W | Maximum junction to case (drain) | Steady state | RthJc | 1.5 | 1.9 |
- 240.74 KB
- VISHAY SiSS5108DN N沟道100V(D-S)MOSFET datasheet
