ABSOLUTE MAXIMUM RATINGS (TA=25 °℃,unless otherwise noted) |
PARAMETER | SYMBOL | LIMIT | UNIT |
Drain-source voltage | VDs | 100 | V |
Gate-source voltage | Vgs | ±20 |
Continuous drain current (TJ=150 ℃ | Tc=25 ℃ | lb | 56.7 | A |
Tc=70℃ | 45.3 |
TA=25 ℃ | 15.2 b,c |
TA=70 ℃ | 12.1 b,c |
Pulsed drain current (t=100 μs | IDM | 150 |
Continuous source-drain diode current | Tc=25℃ | ls | 63.1 |
TA=25℃ | 4.5 b,c |
Single pulse avalanche current | L=0.1 mH | lAs | 25 |
Single pulse avalanche energy | EAs | 31.25 | mJ |
Maximum power dissipation | Tc=25 ℃ | PD | 69.4 | W |
Tc=70℃ | 44 |
TA=25 ℃ | 5 b,c |
TA=70 ℃ | 3.2 b,c |
Operating junction and storage temperature range | Tj,Tstg | -55 to +150 | ℃ |
Soldering recommendations (peak temperature)d,t |
| 260 |
THERMAL RESISTANCE RATINGS |
PARAMETER | SYMBOL | TYPICAL | MAXIMUM | UNIT |
Maximum junction-to-ambient b,1 | t≤10 s | RthJr | 20 | 25 | ℃/W |
Maximum junction-to-case (drain) | Steady state | RthJc | 1.3 | 1.8 |
