AVA-183MP+ 是一款砷化镓 pHEMT MMIC 宽带分布式放大器,工作频率为 0.05 至 18 GHz。该放大器具有 16.5 dB 增益、+24 dBm P1dB、+31 dBm OIP3 和 1.8 dB 噪声系数的典型性能,工作电压为 +8V,电流消耗为 160mA。AVA-183MP+ 集宽带宽、低噪声、高线性度和输出功率于一身,是一款 50Ω 匹配的高动态范围放大器。AVA-183MP+ 的性能特点非常适合用于宽带防御系统和测试测量设备。该放大器采用行业标准的 4x4mm QFN 型封装。
功能图
功能图
重大意义
超宽带,0.05-18 千兆赫
高动态范围
P1dB,典型值 +24 dBm
增益,典型值 16 dB
低噪声图,典型值 1.8 dB
高 OIP3,典型值 +31 dBm
4x4mm 20 引线 QFN 型封装
5G MIMO 和回程无线电系统
卫星通信
测试和测量设备
雷达、EW 和 ECM 防御系统
主要特点
Features | Advantages | Wideband:0.05 to 18 GHz
·Gain,Typ.16 dB | ldeal for use in wideband Electronic Warfare and Test and Measurement transmit signal chains. | High Dynamic Range
·P1dB,Typ.+24 dBm
·OIP3,Typ.+31 dBm
·NF,Typ.1.8 dB | Suitable as a driver amplifier for wideband power amplifier signal chains. | Good Input and Output return Loss | Internally matched to 50Q,this eliminates the need for external matching components making the device easy to
ntegrate | 4x4mm 20-Lead QFN-style package | Small footprint saves space in dense layouts while providing low inductance,repeatable transitions,and excellent
thermal contact to the PCB. |
电气规格1 AT +25°C, VDD = +8V, IDD = 160mA, 除非另有说明
Parameter | Condition (GHz) | Min. Typ. Max. | Units | Frequency Range | | 0.05 | | 18 | GHz | Gain | 0.05
5
10
15
18 | 20.0
157
15.9
15.5
15.2 | 20.6
16.2
16.5
16.3
16.3 | | dB | Input Return Loss | 0.05
5
10
15
18 | | 11.4
20.0
13.6
11.2
15.9 | | dB | Output Return Loss | 0.05
5
10
15
18 | | 14.3
20.0
20.0
20.0
19.3 | | dB | lsolation | 0.05-18 | | 43.0 | | dB | Output Power at 1 dB Compression (P1dB) | 0.05
5
10
15
18 | | +25.8
+24.2
+23.8
+24.4
+24.4 | | dBm | Output Third-Order Intercept Point
(Pour=0dBm/Tone) | 0.05
5
10
15
18 | | +32.7
+32.2
+31.1
+29.3
+27.4 | | dBm | Noise Figure | 0.05
5
10
15
18 | | 7.0
1.5
1.8
2.8
3.6 | | dB | Device Operating Voltage (Vpp) | | +7.75 | +8 | +8.25 | V | Device Operating Current (lbp)² | | | 160 | | mA | Gate Voltage(Vgg) | | | -1.3 | | V | Gate Current (lgg) | | | -0.5 | | μA | Device Current Variation Vs.Temperature | | | 5.4 | | μA/℃ | Device Current Variation Vs.Voltage⁵ | | | 0.208 | | mA/mV |
- 479.21 KB
- AVA-183MP+ 是一款砷化镓 pHEMT MMIC 宽带分布式放大器,工作频率为 0.05 至 18 GHz。该放大器具有 16.5 dB ...
